Author Topic: urgent help putting crank back in  (Read 3517 times)
shakeyCZ
« on: October 10, 2010, 06:27:58 pm »
I have done all I need with the engine and need to put the crank back in the side I  used the crank removal tool on, and I cant get it back in I dont want to bash and un balance all I have done with it any help would be great  ??? :o ;D ;D ;D
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: urgent help putting crank back in
« Reply #1 on: October 10, 2010, 08:05:43 pm »
i'm not familiar with CZ motors but i assume this is what your working on.
with my Yammy motors i place the crank assembly in the freezer, which cools and shrinks it,
and i place the cases in the oven on around 100 celcius, which expands it.
{do a trial run first before placing either part in the oven or freezer to help eliminate any problems that may arise}
use gloves, it helps.
then quickly drop the crank into the case and whalah!
job done.
"flat bickie"
Offline brent j
« Reply #2 on: October 10, 2010, 08:29:59 pm »
The biggest problem with this method is usually the wife ::)
« Reply #3 on: October 10, 2010, 08:36:57 pm »
That's why he's divorsed. ;D
Offline vandy010
« Reply #4 on: October 10, 2010, 09:02:08 pm »
"flat bickie"
shakeyCZ
« Reply #5 on: October 10, 2010, 09:10:52 pm »
yer i use this tech a lot but it just wont go the last 5mm in i think i will try again tomorrow and see what happens, its just now I have to pull it out again >:( >:(
shakeyCZ
« Reply #6 on: October 10, 2010, 09:15:27 pm »
oh yer thanks vandy010 for your help, dose anyone have a different way of doing it?
DR
« Reply #7 on: October 10, 2010, 10:46:25 pm »
not sure this would work on this particular bike but if the crank is threaded on the problem side then you could cut some steel tubing and make a sleeve to slip over and rest against the bearing retainer then use the nut to 'help' pull the crank into the cases.
« Last Edit: October 10, 2010, 10:48:17 pm by Doc »
« Reply #8 on: October 11, 2010, 05:18:06 pm »
Sounds like something in the gearbox is catching or is the problem only in trying to fit the crank into the first crankcase?
shakeyCZ
« Reply #9 on: October 11, 2010, 06:54:05 pm »
yer its just getting the crank back in the first case the flywheel side pops straight on, it sux lots >:( >:( >:(
