Author Topic: XR75 Cheap ?  (Read 28305 times)
Offline KB171
Re: XR75 Cheap ?
« Reply #1 on: January 07, 2008, 08:45:13 am »
Crikey ,for $5,000 you'd want the tank stickers put on straight at least.
Offline AjayVMX
    • VMX Magazine
Re: XR75 Cheap ?
« Reply #2 on: January 08, 2008, 10:37:04 am »
It sure is purty though.... ::)
Just remember that the NOS exhaust pipes can go for >US$1000 each, so there are some difficult to get parts on that bike... ;)
Offline BETRIC
Re: XR75 Cheap ?
« Reply #3 on: January 08, 2008, 02:35:23 pm »
AJ
That XR75 K1 has a modified K4/5 XR75/79 XR80 pipe on it, the tail pipe has been cut off to make it look like an early pipe, you can still buy the late pipes from Honda for $210, their is a few things wrong on the bike, they are
Tire info decal on chain guard, should be on rear guard.
Chain guide & rear brake stay black, should be zinc colour.
Throttle cable through front number plate, should be behind plate.
Uses K2/3 front brake cable guide, should have KO/K1 type behind number plate on plate bracket.
Wrong colour used on engine cases.
Missing taco blanking  plug (rubber) on clutch cover.
Missing rubber caps on clutch/brake levers.
Honda tank wings wrong postion.
Info decals missing on tank.
Rear shock decals facing out should be facing in.
Later model rims used
Front/Rear guards mounting plates are black should be zinc
Wrong finish (polished) on forks/rocker cover/ center fly wheel cover and brake backing plate
Front engine bolts fitted wrong way round.
Exhaust warning decal in wrong postion on swing arm.
Missing the opac plastic band for the kill switch cable.
Clutch cable/kill switch cable not routed through the handle bar clamp guide.
Swing arm bolt has washer on chain side should not be their.
He claims it is perfect and finished as standard, I know I have been a bit anal about this but if you are asking that sort of money he should have done a bit research on finishing this XR75
PS: He strated the auction at $7000 then reduced back to $5000
« Last Edit: January 09, 2008, 10:00:31 am by BETRIC »
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
Re: XR75 Cheap ?
« Reply #4 on: January 08, 2008, 03:12:02 pm »
Jeez Dave, very anal of you! That's the great thing about this forum and the vintage movement in general. If you don't know something about a particular bike there is definitely someone out there who does. I was impressed by your knowledge of these little tiddlers when we had a few beers at the Coffs Nats. I'm amazed you can spot so much wrong with that XR from the photos. Good work.
The latest news from AJ is that he now has two of those GRM, Mexican trials bikes on the water. One will probably be for sale so I'd reckon you'll need it to park next to the Coopers! Catch you at CD5
Offline AjayVMX
    • VMX Magazine
Re: XR75 Cheap ?
« Reply #5 on: January 08, 2008, 03:38:50 pm »
Hey thanks Betric...  :o
Quite a few of those "little things" you have highlighted are pretty easy to fix though.
I must admit that my first viewing of the photos did raise alarm bells regarding the pipe - due to the unusually large size of the outlet.
I also didn't know that the later pipes were still available - I've got a Red XR that needs one... 8)
Maybe there are bits on my K1 that are "more stock" than this one... ;D
Love that orange pipe though!!!
Offline BETRIC
Re: XR75 Cheap ?
« Reply #6 on: January 08, 2008, 04:52:40 pm »
AJAYVMX
YOU SHOULD BE ABLE TO BUY A REPRO XR75 4 SPEED PIPE IN THE COMING MONTHS, I HAVE HAD A STOCK XR75 4 SPEED PIPE OVER IN NZ BEING COPIED BY MUSKET EXHAUST, IT'S BEEN 2yr's SINCE THE PROJECT WAS STARTED WITH MUSKET & RE MX IN THE STATES, AND NOW IT IS JUST ABOUT READY TO BE MANUFACTURED IN NUMBERS, IT WILL COME WITH THE MOUNTING BRACKET,THEY ARE JUST WORKING ON THE CLEARANCE FOR THE KICK STARTER ON THE HEADER PIPE, A LOT OF WORK HAS BEEN PUT INTO THE PIPE TO GET IT RIGHT
Re: XR75 Cheap ?
« Reply #7 on: January 08, 2008, 10:41:06 pm »
and Dan at RE-MX is good value also.
Rossco
Quicksilver
Re: XR75 Cheap ?
« Reply #8 on: January 09, 2008, 02:38:35 pm »
No takers. At 5k not a shock either ;)
kevwrx
Re: XR75 Cheap ?
« Reply #9 on: January 10, 2008, 10:07:22 pm »
Here's mine
All original 1977 Model XR-75 Red Devil Chassis Number 0666
[attachment deleted by admin]
Re: XR75 Cheap ?
« Reply #10 on: January 11, 2008, 02:09:55 am »
kevwrx - was that the first of the XR 75s with the 5 speed box and laid down shocks?  If so then I can remember my brother getting one brand new - brings back some memories!!!
thanks
Rossco
Re: XR75 Cheap ?
« Reply #11 on: January 11, 2008, 07:25:10 am »
thanks
Rossco
Yep, first 5 speeder, model designation is K4 i had one too (my first bike $430 new) great memories.  :)
kevwrx
Re: XR75 Cheap ?
« Reply #12 on: January 11, 2008, 07:27:46 am »
thanks
Rossco
That's the one Rosco  :)
Re: XR75 Cheap ?
« Reply #13 on: January 11, 2008, 01:43:53 pm »
and yours looks nice to - well done!
regards
Rossco
Offline KB171
Re: XR75 Cheap ?
« Reply #14 on: January 11, 2008, 01:54:10 pm »
This is the revised version of my old shitter
