Author Topic: RM125A piston  (Read 15496 times)
Re: RM125A piston
« Reply #15 on: January 15, 2008, 03:44:42 pm »
I have found that a Suzuki TS125R piston is very close and will work by either running it with only the top ring or shifting the bottom ring locating pin.
K.
090
Re: RM125A piston
« Reply #16 on: January 15, 2008, 06:04:49 pm »
Nice one. Now that you mention it, i think that was the mod done to mine (move pin)
Doc
Re: RM125A piston
« Reply #17 on: January 18, 2008, 07:48:40 am »
BigK..the TS125R piston are a 14mm gudgeon opposed to the RM125A 16mm. Does this R designation point to a different (later) R?   '71 and '94 were the only times Suzuki used this designation. (that I know of)
Re: RM125A piston
« Reply #18 on: January 18, 2008, 09:50:59 am »
Pro X part # 01.3007.200 listed to suit Suzuki TSR125. 16mm piston pin.
Doc
Re: RM125A piston
« Reply #19 on: January 18, 2008, 11:37:59 am »
okay..TSR..makes sense BigK..JDM model..this is a '96 model TSR125. Is there any property differences between an aircooled piston and a water cooled piston?? I never looked as anything bar air cooled thinking the watercooled may heat up faster and require different tolerances.. :-\
« Last Edit: January 18, 2008, 11:41:07 am by Doc »
Re: RM125A piston
« Reply #20 on: January 19, 2008, 08:50:46 am »
No difference in my experience in water cooled versus air cooled pistons. I have total confidence this piston will be fine. The bike is going to be raced, so it will be a good test.
Doc
Re: RM125A piston
« Reply #21 on: January 19, 2008, 12:45:47 pm »
I love to hear someone with oodles of confidence!  ;) Thanks for the tip BigK, I can start looking at a whole swag of pistons and rings I'd previously overlooked  ;D
Re: RM125A piston
« Reply #22 on: January 19, 2008, 04:36:32 pm »
Doc, I'm sure the alloy would be the same in all pistons (brand to brand)
Watercooled engines may have a different tollerance but this would be up to the guy that is boring it as they usually bore to suit the piston.
Re: RM125A piston
« Reply #23 on: January 19, 2008, 07:59:11 pm »
Usually there is no real difference between air and watercooled pistons.Water cooled models just run more compression, with todays piston/machining technology you have little to worry about.
To use these pistions in old TM/TS you might need to swap to an RGV rod or such.
