Clubroom
Tech Talk
YZ 465 G /H WHEEL
Topic: YZ 465 G /H WHEEL (Read 2651 times)
over the bars
C-Grade
YZ 465 G /H WHEEL
June 05, 2010, 09:33:03 pm »
Will YZ 465 H back wheel fit into a G ? . I want to run the bigger size brakes . Cheers
E74
Re: YZ 465 G /H WHEEL
June 05, 2010, 09:38:06 pm »
same wheel
over the bars
C-Grade
June 06, 2010, 05:09:45 pm »
Doesnt the H have a bigger diameter brake and larger backing plate or could it be a J back wheel ?
rocketfrog
June 06, 2010, 08:11:52 pm »
The 250 G/H models have different dia drum on the rear. Smaller on the G then larger to H, then back to small again for J.
As E74 says the 465 has large on both models.
Clubroom
Tech Talk
YZ 465 G /H WHEEL
