Author Topic: YZ 465 G /H WHEEL  (Read 2652 times)
Offline over the bars
YZ 465 G /H WHEEL
« on: June 05, 2010, 09:33:03 pm »
Will  YZ 465 H back wheel fit into a G ? . I want to run the bigger size brakes . Cheers  ???  ???  ???
Offline E74
Re: YZ 465 G /H WHEEL
« Reply #1 on: June 05, 2010, 09:38:06 pm »
same wheel
« Reply #2 on: June 06, 2010, 05:09:45 pm »
Doesnt the H have a bigger diameter brake and larger backing plate or could it be a J back wheel ?  ???
Offline rocketfrog
« Reply #3 on: June 06, 2010, 08:11:52 pm »
The 250 G/H models have different dia drum on the rear. Smaller on the G then larger to H, then back to small again for J.
 As E74 says the 465 has large on both models.
