Author Topic: What Type of Steel is Steel made of ??  (Read 5231 times)
« on: May 24, 2010, 07:09:39 pm »
Re: What Type of Steel is Steel made of ??
« Reply #1 on: May 24, 2010, 07:13:58 pm »
 :D
hmmmm.......... very deep, i will ponder this and world peace and get back to you.
« Last Edit: May 24, 2010, 07:35:45 pm by Hoony »
Offline vmx42
« Reply #2 on: May 24, 2010, 07:31:28 pm »
Why didn't I think of that? Pure Gold!
« Reply #4 on: May 24, 2010, 09:13:17 pm »
Carbon Steel CS 1020
C   Carbon       0.17 – 0.23 %
Mn   Manganese   0.3 – 0.6 %
P   Phosphorus   0.04 % max
S   Sulphur      0.05 % max
Fe   Iron       Balance
Tensile strength 460 Mpa
Alloy Steel Chrome Moly – 4130
C   Carbon       0.28 – 0.33 %
Cr   Chromium   0.8 – 1.1 %
Mn   Manganese   0.4 – 0.6 %
Mo   Molybdenum   0.15 – 0.25 %
P   Phosphorus   0.035 % max
S   Sulphur      0.04 % max
Si   Silicon      0.15 - .-0.35 %
Fe   Iron       Balance
Tensile strength 670 Mpa
(4130 alloy is noted for its weldability by all of the commercial methods.)
Some of you guys have too much time on your hands
 ;D ;D
« Reply #5 on: May 24, 2010, 10:35:42 pm »
The same could be said about you Mr Morris.....have you run out of firewood yet?.....shorts and T-shirt today......I know you can smell Conondale from down there....theres a bed in Brad's semi-trailer waiting for you!!!.......you could always tell the cheese and kisses that you have to go to QLD to do some welding schools?...and drop off some completed ( ;D) jobs on the way.
« Reply #6 on: May 24, 2010, 10:36:20 pm »
Hey Geoff, I've been looking for the makeup of Reynolds steel. I want to see how close or far away it is to Chro-Mo. I TIG welded a mild steel bracket to my Cheney swingarm on the weekend and Chrome Moly and SS rods sucked. I ended up getting a good result with common old copper coated mild steel rods. I hope it holds as it's a brake stay!
« Reply #7 on: May 25, 2010, 07:43:53 am »
No time for Qld, been wasting too much time reading all the shit on this site :D :D
Reynolds 531
Carbon: .23-0.29%
Sulfur: 0.045% max
Silicon: 0.15-0.35%
Phosphorous: 0.045% max
Manganese: 1.25-1.45%
Molybdenum: 0.15-0.25%
Tensile strength 120,000 Psi    I can't be bothered converting this to Mpa, got real work too do (like taking Qlders money ;D)
Interesting, I would have thought it would have welded with the stainless OK
« Reply #8 on: May 25, 2010, 07:55:25 am »
I think the old boys lost it Geoff....you know the old saying.....a good tradesman never blames his tools!! ;D....can you whip up one of those walking frames in time for CD....put one of those lawnmower clutches in it and a Villiers engine....and a straight through exhaust...Tanner wont be able to ping em there!! ;D
« Reply #9 on: May 25, 2010, 08:53:59 am »
Normaly that's true but it doesn't count when working with Pommy stuff ;D ;D
For many years the only recommended way to assemble a frame was by fillet brazing or brazing with lugs, and this was the way 531 frames were constructed. When Reynolds introduced 753, due to the nature of the material, these tubes needed to be low temperature silver soldered.
We now have a new generation of materials in 525, 725, 631, 853 and 953 steels. All of these can be brazed, but the most popular method of assembly is by TIG welding. (on 853 we do recommend that gear fittings etc are silver soldered onto the tubes).
There are many filler wires that can be used on 525/725/631/853 like ER-70S-6.
From
http://reynoldstechnology.biz/faqs/welding_joining/1
« Reply #10 on: May 25, 2010, 09:58:25 am »
I forgot to mention that it's an old Cheney frame, made from 531 Reynolds. I've been told Simon makes them out of 4130 these days but I may be wrong.
I would have brazed the bracket but I was trying to save as much nickel plating as possible so figured TIG would produce more localised heat and not damage or discolour the plating. It surprised me about the rods though. I was getting blowback with both Chrome-Moly and Staino rods but good old copper coated oxy rods flowed like toothpaste out of a tube. I was a tad worried that cracks may appear so I gave it some healthy boilermaker standard whacks with a hammer both when it was hot and once cooled and no problems appeared whatsoever.
« Reply #11 on: May 25, 2010, 01:38:06 pm »
so can you braze using a tig or can you only do this with oxzy ???
Ji Gantor
« Reply #12 on: May 25, 2010, 03:11:33 pm »
You can only braze with Oxy.
Ji
Offline AjayVMX
    • VMX Magazine
« Reply #13 on: May 25, 2010, 05:10:13 pm »
Not sure what type of Steel, Steel is made of...  but I know it can be made in one of these:
And if I'm not very much mistaken, that's Mr Steel making an appearance as we speak.  ;)
« Reply #14 on: May 25, 2010, 09:34:40 pm »
Actually you can braze with a MIG too
Silicon Bronze & Phosphor Bronze wires are available, I used some years ago for welding Bronze angle iron
