Author Topic: what can be done to get a xl350 going???????  (Read 7112 times)
« on: March 20, 2010, 06:30:51 pm »
there has been a few threads about the xl350 latley what do you need to get one to go well
see if i can be converted from a tt500 as they are much lighter
jim
Offline dirttracker
Re: what can be done to get a xl350 going???????
« Reply #1 on: March 20, 2010, 06:39:03 pm »
the best way to get it going is to use the kickstarter as they did not come with an electric start, if that fails try to run start it.
Offline fatboyracing
« Reply #2 on: March 20, 2010, 06:44:32 pm »
Start with a 420 kit ,electronic ignition and a bigger carby all these things will help to get the old girls going a lot harder than they did before .
The biggest improvement was the electronic ignition made it start easy and gives you a good strong blue spark instead of the very weak spark you get with points.
Fatboy
090
« Reply #3 on: March 20, 2010, 08:25:19 pm »
Getting rid of the flywheel weight seems to be a big part
Curly3
« Reply #4 on: March 20, 2010, 09:53:23 pm »
It was always my understanding that Flywheel weight was a very important ingredient in a competitive Dirt Track engine, eg - full throttle pretty much 100% of the time, very little stop start corners. Knowing the Engine under you will hold Revs and not bog down half way through a corner is a major factor. In theory it sounds good but I'm not sure if I'm still game enough to try it out.
Offline 52
« Reply #5 on: March 25, 2010, 07:36:05 pm »
I know where you r coming from Curly, but when you look at modern 4/strokes there ain't much weight there. I'm of the popular opinion - bin it.
mattsaggus
« Reply #6 on: March 29, 2010, 09:31:17 pm »
Hi Mate
The flywheel weight reason is true on a weak engine.
BUT
If you up the hp enough the last you want is a weight dragging it down.
Carby
cam
ports
valve springs
mill out the piston, ceramic coat the top so you can run it lean,
Teflon buttons on piston skirt to reduce drag,
exhaust port it
exhaust pipe it
ignition
or simply
Put me on it, LOL.
Matt
« Reply #7 on: March 29, 2010, 10:06:23 pm »
twist your wrist  8)
« Reply #8 on: March 30, 2010, 02:32:33 am »
jim
Push it up to the top of the highest bluff you can find Jim, give it a nudge, you should be able to improve its acceleration by about 9.81 m/s².
« Last Edit: March 30, 2010, 02:41:32 am by MICK-DE »
« Reply #9 on: March 30, 2010, 09:48:54 am »
....................... you should be able to improve its acceleration by about 9.81 m/s².
Mick, you know you physics  :D
« Reply #10 on: March 30, 2010, 10:18:33 am »
he needs to
to know how much force is needed to push maicos sometimes they start most times they dont
« Reply #11 on: March 30, 2010, 02:13:11 pm »
he needs to
       That only happens because of incompetent assembly and service. And I have a better excuse anyhow, I am removing all kicker mechanisms to reduce weight in my struggle to approach terminal velocity.
       Keep doing them push ups and eating your wheat bix Jim, cause I don’t see any hills at the DT Nats track. And yehp, you guessed it, my quickshade will be going up next to yours, and I will be needing a push Jim.
« Reply #12 on: March 30, 2010, 04:20:44 pm »
no problem i will be there to lend a hand
jim
Offline sudman
« Reply #13 on: March 30, 2010, 07:54:05 pm »
Fatboy
What electronic ignition did you use?
« Reply #14 on: March 30, 2010, 09:05:53 pm »
Used one out of a postie bike just needed to get the stator rewound to suit.It made a huge difference.
Fatboy
