Marketplace
Wanted
yz 125f crank
Topic: yz 125f crank (Read 1987 times)
juzze
yz 125f crank
February 19, 2010, 05:40:49 pm »
Hi just wondering if any one has a yz125 f crank they would like to sell i just pulled my motor apart and noticed some bodgy prick welded the big end pin up.
TT5 Matt
Re: yz 125f crank
February 19, 2010, 09:13:18 pm »
pm sent
Viper666
"Yes I bought THAT number plate" so sue me!
Re: yz 125f crank
February 22, 2010, 10:29:26 am »
Depending on the weld job, doesn't mean it's dodgey. Some crank builders did this as par for course.
Also after a few rod replacement they do get looser so they are often welded.
YZ80H, YZ100G, YZ125E, YZ125F, YZ125G, YZ250D, YZ250E, YZ250F, YZ250G, YZ250H, YZ400F, IT125G, IT250K & a, a, a, CRF250X?
juzze
Re: yz 125f crank
February 22, 2010, 09:19:14 pm »
Its just very anoying when u go to change the big end and you see it welded up your deffinently wright its not bodgey i chose a bad way to explain it after seeing it.
Dirtbike BrainwashedMike
Novice
Re: yz 125f crank
February 26, 2010, 05:07:26 am »
Hi, I have yz125 D crank marked 1wi on the rod. Not sure if it's the same as the F. It will need rod kit. I'm on the NSW Central Coast if you want a look. If it's any good to you, make an offer.
juzze
Re: yz 125f crank
February 28, 2010, 09:29:06 pm »
Hi ill try find out if it is the same as mine thanks heaps.
Viper666
Re: yz 125f crank
March 02, 2010, 05:39:10 pm »
They're different on the rotor side. 77 has fat tapper like for a flywheel, 79 onwards have the skinny tapper.
Viper666
juzze
Re: yz 125f crank
Reply #7 on:
March 07, 2010, 07:53:34 pm »
Thanks heaps viper
Marketplace
Wanted
yz 125f crank
