Author Topic: yz 125f crank  (Read 1785 times)
juzze
yz 125f crank
« on: February 19, 2010, 05:40:49 pm »
Hi just wondering if any one has a yz125 f crank they would like to sell i just pulled my motor apart and noticed some bodgy prick welded the big end pin up.
Re: yz 125f crank
« Reply #1 on: February 19, 2010, 09:13:18 pm »
pm sent
Offline Viper666
    • Ballarat Rovers MCC
Re: yz 125f crank
« Reply #2 on: February 22, 2010, 10:29:26 am »
Depending on the weld job, doesn't mean it's dodgey. Some crank builders did this as par for course.
Also after a few rod replacement they do get looser so they are often welded.
juzze
Re: yz 125f crank
« Reply #3 on: February 22, 2010, 09:19:14 pm »
Its just very anoying when u go to change the big end and you see it welded up your deffinently wright  its not bodgey i chose a bad way to explain it after seeing it.
Offline Dirtbike BrainwashedMike
Re: yz 125f crank
« Reply #4 on: February 26, 2010, 05:07:26 am »
Hi, I have yz125 D crank marked 1wi on the rod. Not sure if it's the same as the F. It will need rod kit. I'm on the NSW Central Coast if you want a look. If it's any good to you, make an offer.
juzze
Re: yz 125f crank
« Reply #5 on: February 28, 2010, 09:29:06 pm »
Hi ill try find out if it is the same as mine thanks heaps.
Offline Viper666
Re: yz 125f crank
« Reply #6 on: March 02, 2010, 05:39:10 pm »
They're different on the rotor side. 77 has fat tapper like for a flywheel, 79 onwards have the skinny tapper.
Viper666
juzze
Re: yz 125f crank
« Reply #7 on: March 07, 2010, 07:53:34 pm »
Thanks heaps viper
