Author Topic: Classic Dirt Track Images.  (Read 1290093 times)
Curly3
Re: Classic Dirt Track Images.
« Reply #885 on: May 31, 2012, 07:46:00 pm »
I finally got my hands on this photo.
Billy Mac on my fathers Elstar BSA at Amaroo Park, 1968.
[IMG]http://i49.tinypic.com/9qxo4w.jpg[/I
« Reply #886 on: May 31, 2012, 07:48:23 pm »
Curly3
« Reply #887 on: May 31, 2012, 07:52:01 pm »
Thanks Hoony, I wouldn't have the patience right now to sort out what I done wrong.
I was the last person to ride the bike and it was on the same track, around 1980, it's in my shed awaiting some lovin.
Cheers, Steve
« Last Edit: May 31, 2012, 08:00:01 pm by SlideRulz »
« Reply #888 on: June 01, 2012, 01:25:00 am »
slides you just cut of the end -- should have ended [/img] thats all.
Hollywood
« Reply #889 on: June 02, 2012, 03:22:38 pm »
Heddon Greta
Heddon Greta
This home built frame by my brother was copied from Jeffo's first Hagon using photographs. My brother was a carpenter and drew it full scale onto a sheet of Masonite. Considering he worked in wood all the time, he did a pretty good job.
The completed 350cc BSA slotted into the home built Hagon
Well, sadly that is the last of our photographs.
Offline pancho
« Reply #890 on: June 03, 2012, 05:44:32 pm »
 O.K, I have managed to load some pics onto photobucket.
 Can some-one explain to this older gentleman who is loosing his cool what to do to get them on here please?
pancho.
« Reply #891 on: June 03, 2012, 06:46:24 pm »
here you go Pancho, its quite easy once you get used to it. the forum link below spells it out, open up another tab to view the link ( keep this tab open) and open yet another tab where your pics are then toggle between the 3 tabs to follow the link below.
http://ozvmx.com/community/index.php?topic=6667.0
hope this helps you out.
if not what i do is upload my pics to the Ning OZVMX site and then link them to the post i want on here.
« Last Edit: June 03, 2012, 06:47:57 pm by Hoony »
« Reply #892 on: June 03, 2012, 06:55:42 pm »
Wally from one older gentleman to another........run your curser over the photo and a drop window will appear. click on the 'img code' until the word 'copied'appears. Then go to where you want to place the photo, say on the forum post you're creating and right click and a window will appear. Right click on Post and the photo url should appear on the page. Click on the 'Preview' button below to check to see if your photo comes out properly and if so, press Post. You can go past the preview button once you have confidence in your ability to get through the process. The more you do it, the simpler it becomes.
Offline pancho
« Reply #893 on: June 03, 2012, 08:42:52 pm »
 thank you gents, I'll try again tomorrow.
cheers pancho.
« Reply #894 on: June 04, 2012, 10:44:22 am »
I reckon there would be a YOur tube video tutorial on that for sure.   Just google it.... lazy old mans way.   (from one lazy old man to another )
« Last Edit: June 04, 2012, 09:12:59 pm by Freakshow »
Offline pancho
« Reply #895 on: June 04, 2012, 06:11:45 pm »
Offline pancho
« Reply #896 on: June 04, 2012, 06:14:19 pm »
 O K there's one! now to try again!
 Who are they and where, any guesses?
pancho.
Curly3
« Reply #897 on: June 04, 2012, 06:22:22 pm »
Amaroo Park but I have no idea who, one is from Wallsend.
ianaust
« Reply #898 on: June 04, 2012, 06:24:11 pm »
Amaroo Park coming out of pit corner and its Bill Dillow on the outside but Wallsend guy not sure
Offline pancho
« Reply #899 on: June 04, 2012, 06:26:15 pm »
 The bloke with his head in front is Bill Dillow, I think the other is Kevin Frazer,
 Was that K.F.'s number back then?
pancho.
