Author Topic: rm125s small end bearig  (Read 3564 times)
« on: December 03, 2009, 11:19:49 pm »
went down to the local suzuki dealer to order a small end bearing for my rm125s to find out the part is no longer available so is there any other brands that use the same size bearing 14x18?
Re: rm125s small end bearig
« Reply #1 on: December 03, 2009, 11:58:14 pm »
Any 14mm small end bearing will be fine so long as roughly aligned in the centre of the rod eye.
« Reply #2 on: December 04, 2009, 12:15:14 am »
yeah i know that the bearing has got to be wide enough to do the job but what other brands will do like cr/mt125 honda small end bearing's as they use a 14mm pin as well.
TM BILL
« Reply #3 on: December 04, 2009, 05:29:09 am »
TS 125, TM 125, TC 125, RM 125B, C , TF 125
trailietrash
« Reply #4 on: December 04, 2009, 07:02:39 am »
I doubt that I just bought the last one as they fit mx, trail, off road, road and outboard motors..... 09263-14022
maybe try another dealer  ;)
« Last Edit: December 04, 2009, 07:05:53 am by trailietrash »
DR
« Reply #5 on: December 04, 2009, 08:14:16 am »
run this list by them as they're all the same bearing and the 14022 is the most recent. The DT9.9, DT15 and DT16 zooki outboards of the 90's also use the same bearing ;)
09263-14001
09263-14004   14x18x19.8
09263-14005   14x18x19.8
09263-14006   14x18x19.8
09263-14007   14x18x19.8
09263-14008   14x18x19.8
09263-14012   14x18x19.8
09263-14014   14x18x19.8
09263-14019   14x18x19.8
09263-14022   14x18x19.8
« Reply #6 on: December 04, 2009, 12:20:22 pm »
suzuki must use the same system honda uses every time they change parts supplier's and they change the last 1/2 number's of the part number,as i said before that i have been to the dealer's with up to date puter superceed/price but there no bearing's in oz.so if the local bearing supply shop could get the size i want would it be up to the job and not lunch my motor with broken needle roller's?
DR
« Reply #7 on: December 04, 2009, 12:45:16 pm »
Matt, I was just over at Team Moto at Virginia up here in Briz, the spares guy punched in 09263-14022 and yup..plenty of stock available ex Suzuki Aust ;)
« Last Edit: December 04, 2009, 12:47:08 pm by Doc »
« Reply #8 on: December 04, 2009, 12:55:36 pm »
thanks Doc it was 6 months ago that i asked so maybe suz aust has a new batch in,i go down this arvo and reorder it
« Reply #9 on: December 04, 2009, 10:52:55 pm »
Local bearing supply quotes for that size to OEM standard. $11.80
