Marque Remarks
Suzuki
rm125s small end bearig
Topic: rm125s small end bearig (Read 3550 times)
TT5 Matt
December 03, 2009, 11:19:49 pm »
went down to the local suzuki dealer to order a small end bearing for my rm125s to find out the part is no longer available so is there any other brands that use the same size bearing 14x18?
Lozza
Re: rm125s small end bearig
December 03, 2009, 11:58:14 pm »
Any 14mm small end bearing will be fine so long as roughly aligned in the centre of the rod eye.
TT5 Matt
December 04, 2009, 12:15:14 am »
yeah i know that the bearing has got to be wide enough to do the job but what other brands will do like cr/mt125 honda small end bearing's as they use a 14mm pin as well.
TM BILL
December 04, 2009, 05:29:09 am »
TS 125, TM 125, TC 125, RM 125B, C , TF 125
trailietrash
Reply #4 on:
December 04, 2009, 07:02:39 am »
I doubt that I just bought the last one as they fit mx, trail, off road, road and outboard motors..... 09263-14022
maybe try another dealer
Last Edit: December 04, 2009, 07:05:53 am by trailietrash
DR
Reply #5 on:
December 04, 2009, 08:14:16 am »
run this list by them as they're all the same bearing and the 14022 is the most recent. The DT9.9, DT15 and DT16 zooki outboards of the 90's also use the same bearing
09263-14001
09263-14004 14x18x19.8
09263-14005 14x18x19.8
09263-14006 14x18x19.8
09263-14007 14x18x19.8
09263-14008 14x18x19.8
09263-14012 14x18x19.8
09263-14014 14x18x19.8
09263-14019 14x18x19.8
09263-14022 14x18x19.8
TT5 Matt
Reply #6 on:
December 04, 2009, 12:20:22 pm »
suzuki must use the same system honda uses every time they change parts supplier's and they change the last 1/2 number's of the part number,as i said before that i have been to the dealer's with up to date puter superceed/price but there no bearing's in oz.so if the local bearing supply shop could get the size i want would it be up to the job and not lunch my motor with broken needle roller's?
DR
Reply #7 on:
December 04, 2009, 12:45:16 pm »
Matt, I was just over at Team Moto at Virginia up here in Briz, the spares guy punched in 09263-14022 and yup..plenty of stock available ex Suzuki Aust
Last Edit: December 04, 2009, 12:47:08 pm by Doc
TT5 Matt
Reply #8 on:
December 04, 2009, 12:55:36 pm »
thanks Doc it was 6 months ago that i asked so maybe suz aust has a new batch in,i go down this arvo and reorder it
Tim754
Northern Country Victoria
Reply #9 on:
December 04, 2009, 10:52:55 pm »
Local bearing supply quotes for that size to OEM standard. $11.80
Marque Remarks
Suzuki
