Author Topic: 1983 cr480 Blog  (Read 10749 times)
Offline flyingdg
1983 cr480 Blog
« on: November 18, 2009, 12:28:15 am »
I have a new blog on a 83 cr480 build. come and check it out. DG
http://1983cr480.blogspot.com/?spref=fb
090
Re: 1983 cr480 Blog
« Reply #1 on: November 18, 2009, 07:19:51 pm »
Seems you have to have an account of some type to comment. I was going to comment on the cases. I have a set of cases off an '82 that have the same crack.
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #2 on: November 19, 2009, 07:57:26 am »
I got a email today and the person was telling me as a honda machanic he had fixed two or three cr480 cases that had cracks in them like mine. He said that they would weld them and never had a problem with them again. DG
Offline mick25
  • Hunter valley NSW
Re: 1983 cr480 Blog
« Reply #3 on: November 20, 2009, 10:40:09 am »
It must be a common case with the case cracking, i had a cr 480 82 and had a crack in the case as well  :'(
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #4 on: November 20, 2009, 12:09:43 pm »
I fixed the blog, now i think you can post. I milled the weld down today on the case. Go to the blog and see the photos. DG
Offline caps 999
Re: 1983 cr480 Blog
« Reply #5 on: November 20, 2009, 12:18:55 pm »
yeh its a common problem apperantly its caused by the torque snap of hole shoting them
MUGEN power
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #6 on: December 24, 2009, 09:47:21 am »
I have some updates on the 1983 cr480 build.
« Last Edit: January 07, 2010, 07:30:20 am by flyingdg »
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #7 on: January 07, 2010, 07:31:19 am »
I have some new posts on the 83 cr480 build. DG
STW996
Re: 1983 cr480 Blog
« Reply #8 on: January 07, 2010, 05:07:32 pm »
Coming along very nicely!!
Keep the photo's coming.
Also good touch putting the contact names for parts the fork wipes look the part so I am going to contact Bobby.
Shane
Offline pirie593
Re: 1983 cr480 Blog
« Reply #9 on: January 07, 2010, 06:56:30 pm »
Never had a problem with my 82 model.  Always started in 2nd gear, blew them away to the first corner......and then I woke up !!!!
Ran an 82 for 3 years without any issues...bullet proof.
Offline caps 999
Re: 1983 cr480 Blog
« Reply #10 on: January 07, 2010, 11:12:53 pm »
yea my 82 is perfect inside but thats what ive been told is the cause
MUGEN power
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #11 on: January 14, 2010, 06:46:44 am »
I posted some more photos and here is a link for the EX manifold' check out the billet kick starter for the trx250r, would that work on the 83 cr's? check out the cylinder's and head, would that bolt up to a 83 cr250? also check out the CPI pipe for a cr500 very cool! this is the guy that built the proto pipe for ATK and there first liquid cooled 250 in the early 90's with the big fat section in it, ATK had FMF see if they could build a better pipe than CPI and they could not, about 6 monthes after that FMF had a new pipe called the fatty and it looked alot like CPI's pipes. Thanks DG
http://www.eddie-sanders-racing.com/oscmax/
http://www.cpiracing.com/
« Last Edit: January 14, 2010, 06:58:59 am by flyingdg »
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #12 on: January 14, 2010, 08:08:52 am »
If you can't find the kick starter here it is. DG
http://www.eddie-sanders-racing.com/oscmax/index.php?cPath=2_44_19
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #13 on: January 30, 2010, 11:04:21 am »
I have posted some more updates on the 83 cr480 build. DG
Offline flyingdg
Re: 1983 cr480 Blog
« Reply #14 on: February 09, 2010, 07:40:59 am »
I had Steve Stasiefski factory mechanic for Brad Lackey at my home this last week so I had him put the bottom end together on the 480, check out the photos. DG
