Author Topic: mikuni 36mm jetting for a 250 monty enduro  (Read 2840 times)
lms6201
« on: November 09, 2009, 03:26:22 pm »
for a h6  54m 1977 , i,ve got the 36mm carby and a selection of jets and slides , i also have a tm34 mikuni if anyone has an opinion on how that would go ?  thanks
felix7
Re: mikuni 36mm jetting for a 250 monty enduro
« Reply #1 on: November 18, 2009, 11:01:46 pm »
I posted this a while back regarding my Mk8 250 Blly. Theoretically should be the same or damn close. The info came from: Mikuni maestro Ian Williams has been extremely helpful. He went through his records and reckons this is about the combo I should have in my 250:
 - VM34, 210 main, 35 pilot, 2.5 cutaway slide, 6DP1 needle, Q-5 needle jet and 2.0 airjet.
- Felix
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #2 on: November 19, 2009, 01:46:33 am »
VM34. Baseline jetting for 250cc Montesa's.
Main jet-250
Pilot jet-35
Needle-6FJ6
Needle jet-159Q6
Slide-2.5
remove and toss the airjet.
Offline norm17
« Reply #3 on: November 19, 2009, 08:36:09 am »
If you go tp either of Luke1961's Skydrive sites there is a Sudco Mikuni Manual that we posted there recently.
Whilst it won't address specifically a Montessa 250 it does give baseline specs for various bikes plus detailed listings of just what jet/needle/etc is richer/leaner etc because they are not logically sequential.
PE   http://cid-407d7ef0965d3991.skydrive.live.com/browse.aspx/Pure%20Enduro
RM   http://cid-407d7ef0965d3991.skydrive.live.com/browse.aspx/Racing%20Model
The above Link is given direct in a posting called Sudco Mikuni Manual in Tech Talk from November 12 2009
Norm
