Author Topic: pe400 rm400  (Read 8425 times)
Offline caps 999
pe400 rm400
« on: November 05, 2009, 12:02:20 am »
will the motors inter change
MUGEN power
Re: pe400 rm400
« Reply #1 on: November 05, 2009, 01:04:50 am »
NO. 2 totally different motors. Basically about the only parts interchangeable are the magneto and clutch cover screws and a couple small parts if your lucky, thats how different they are.
Offline caps 999
Re: pe400 rm400
« Reply #2 on: November 05, 2009, 08:43:25 am »
so a pe400 motor wont fit in a rm400 frame
MUGEN power
Re: pe400 rm400
« Reply #3 on: November 05, 2009, 02:53:55 pm »
CAPS - talking second hand here but a friend of mine has a PE in an RM I think - drop him a line - I will PM you his email address.
Rossco
PS I think the 400 is still for sale actually.
Re: pe400 rm400
« Reply #4 on: November 05, 2009, 05:22:51 pm »
YES .... need front alloy engine plates to match  ;)
Leith ... PE 250- 400 share the same frame , as with RM 250 -400 Ditto
           I have a Rm 250 in a PE 250 frame  ;)
Re: pe400 rm400
« Reply #5 on: November 05, 2009, 05:31:02 pm »
yep i knew that, i thought he was asking about if motor parts will interchange.
Offline caps 999
Re: pe400 rm400
« Reply #6 on: November 05, 2009, 07:08:52 pm »
sweet reason being i got a rm400 roller no engine ;D
MUGEN power
Offline frostype400
Re: pe400 rm400
« Reply #7 on: November 05, 2009, 08:32:38 pm »
Same caps I have a rm400 roller and a pe400 roller if you know of a pe400 motor give me a hoy thanks Michael. :)
1971 tm400 and PE's
maxvmx
Re: pe400 rm400
« Reply #8 on: November 08, 2009, 04:24:42 pm »
Man, what I wouldn't give for a RM 250 / 400 roller, I've engineered the shit out of a PE 400 frame so far to get it where I want it but at the end of the day a RM frame would have sufficed nicely - that said, a PE 250 or 400 motor will sit in a RM frame with the exception of the front mount being different on the 400's (15 minutes work to make new mounts) At the risk of trying to re invent the wheel, I am currently going hard modifying a PE 400 motor and frame to a place they were never designed to be! Shit someone has to do it!!
Offline frostype400
Re: pe400 rm400
« Reply #9 on: November 08, 2009, 04:34:05 pm »
Pe400 are still good motors none the less I have a rm400c roller I hope to do up thanks Michael. :)
1971 tm400 and PE's
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: pe400 rm400
« Reply #10 on: November 08, 2009, 06:10:52 pm »
The PE250 was based on the RM250 frame.
The PE175 was based on the RM125 frame.
I don't quite see the disconnect?
Offline frostype400
Re: pe400 rm400
« Reply #11 on: November 08, 2009, 06:16:34 pm »
pe400 frame is quite similar to 250t/x frame aswell and the 400 is only ten kilo heavier thanks Michael. :)
1971 tm400 and PE's
Re: pe400 rm400
« Reply #12 on: November 08, 2009, 06:43:53 pm »
The PE250 & 400 T/X/Z frames are not just similar, they are exactly the same.
Offline frostype400
Re: pe400 rm400
« Reply #13 on: November 08, 2009, 06:45:12 pm »
not exactly the same one is stamped 400 the other 250. ;)
1971 tm400 and PE's
Re: pe400 rm400
« Reply #14 on: November 08, 2009, 07:39:13 pm »
Tooshay  ;D
