Marketplace
Wanted
Ohlins Shock Tools
Topic: Ohlins Shock Tools (Read 3005 times)
Ji Gantor
Ohlins Shock Tools
October 27, 2009, 11:38:20 pm »
Ohlins shocks service tools.
Ji
Ji Gantor
Re: Ohlins Shock Tools
October 28, 2009, 09:17:01 am »
I would like to purchase all tools required to service piggy back gas/oil shocks.
Ji
Ji Gantor
October 28, 2009, 09:31:38 am »
Where would one purchase said tools.
Ji
LWC82PE
Superstar
October 28, 2009, 09:54:42 am »
I have these 2 for sale. Brand new, never used. 2 pin tool fits TT44 shocks and MX USD front fork caps and 51mm reservoir clamping sleeve fits all twins and most singles. They are genuine Ohlins tools. They are pretty expensive, but very good. Its cheaper if you can make your own.
Last Edit: October 28, 2009, 09:59:08 am by LWC82PE
Ji Gantor
October 28, 2009, 09:57:15 am »
Hi LWC82PE,
What does the two pin thingy do?
My shocks are 36mm diameter res.
Ji
LWC82PE
Superstar
October 28, 2009, 10:02:03 am »
The pin tool is only for later shocks/forks for undoing caps with 2 pins. The 51mm clamp is for the gold alloy reservoirs which measure 51mm OD with 44mm internal piston.
Ji Gantor
October 28, 2009, 10:11:15 am »
Thanks LWC82PE,
So these two tools will not work on my shocks, Pitty.
Ji
Marketplace
Wanted
Ohlins Shock Tools
