Author Topic: Ohlins Shock Tools  (Read 3006 times)
Ji Gantor
Ohlins Shock Tools
« on: October 27, 2009, 11:38:20 pm »
Ohlins shocks service tools.
Ji
Ji Gantor
Re: Ohlins Shock Tools
« Reply #1 on: October 28, 2009, 09:17:01 am »
I would like to purchase all tools required to service piggy back gas/oil shocks.
Ji
Ji Gantor
« Reply #2 on: October 28, 2009, 09:31:38 am »
Where would one purchase said tools.
Ji
« Reply #3 on: October 28, 2009, 09:54:42 am »
I have these 2 for sale. Brand new, never used. 2 pin tool fits TT44 shocks and MX USD front fork caps and 51mm reservoir clamping sleeve fits all twins and most singles. They are genuine Ohlins tools. They are pretty expensive, but very good. Its cheaper if you can make your own.
« Last Edit: October 28, 2009, 09:59:08 am by LWC82PE »
Ji Gantor
« Reply #4 on: October 28, 2009, 09:57:15 am »
Hi  LWC82PE,
What does the two pin thingy do?
My shocks are 36mm diameter res.
Ji
« Reply #5 on: October 28, 2009, 10:02:03 am »
The pin tool is only for later shocks/forks for undoing caps with 2 pins. The 51mm clamp is for the gold alloy reservoirs which measure 51mm OD with 44mm internal piston.
Ji Gantor
« Reply #6 on: October 28, 2009, 10:11:15 am »
Thanks LWC82PE,
So these two tools will not work on my shocks, Pitty.
Ji
