Clubroom
General Discussion
Cylinder Sleeves
Topic: Cylinder Sleeves (Read 5336 times)
ozktm
A-Grade
Cylinder Sleeves
November 06, 2007, 12:33:00 pm »
Can anyone point me in the right direction to have a cylinder sleeve made up the would be an exact copy of my original?
Regards,
Adrian #101
Regards,
Adrian Goold #101
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
Re: Cylinder Sleeves
November 06, 2007, 02:00:28 pm »
an original of what ? Blanks or pre cuts
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
Rossvickicampbell
November 06, 2007, 02:09:36 pm »
do a search for LA Sleeves - basically cover the market although they only sell to shops - Serco is the Oz agent if I remember. Also try Wiseco as they do sleeves also.
Rossco
211kawasaki
November 06, 2007, 02:36:24 pm »
Rossandvicki are spot on, I just used an LA Sleeve on my KX and its perfect, had the local rebore guy install and he did a spot on job.
tanner
magoo
Reply #4 on:
November 06, 2007, 03:46:24 pm »
With your maintenance you might need to order a bullet proof sleeve, or maybe a six pack. If you buy them in bulk they might be cheaper.
ozktm
A-Grade
Reply #5 on:
November 07, 2007, 11:30:48 am »
Sleeve is for an 81 KTM 250, so not an of the shelf item. I have an example to be used as a copy.
Regards,
Adrian Goold #101
Gerard De Ruyter (Twistandshout)
A-Grade
Reply #6 on:
November 07, 2007, 11:59:05 am »
The amount of metal removed from that sleeve Adrian, it probably resembles a macrame top rather than a bore - more holes in it than george bush's wmd story.
Clubroom
General Discussion
Cylinder Sleeves
