Author Topic: Cylinder Sleeves  (Read 5340 times)
Offline ozktm
Cylinder Sleeves
« on: November 06, 2007, 12:33:00 pm »
Can anyone point me in the right direction to have a cylinder sleeve made up the would be an exact copy of my original?
Regards,
Adrian #101
Regards,
Adrian Goold #101
Re: Cylinder Sleeves
« Reply #1 on: November 06, 2007, 02:00:28 pm »
an original of what ? Blanks or pre cuts
« Reply #2 on: November 06, 2007, 02:09:36 pm »
do a search for LA Sleeves - basically cover the market although they only sell to shops - Serco is the Oz agent if I remember.  Also try Wiseco as they do sleeves also.
Rossco
211kawasaki
« Reply #3 on: November 06, 2007, 02:36:24 pm »
Rossandvicki are spot on, I just used an LA Sleeve on my KX and its perfect, had the local rebore guy install and he did a spot on job.
tanner
magoo
« Reply #4 on: November 06, 2007, 03:46:24 pm »
With your maintenance you might need to order a bullet proof sleeve, or maybe a six pack. If you buy them in bulk they might be cheaper.
Offline ozktm
« Reply #5 on: November 07, 2007, 11:30:48 am »
Sleeve is for an 81 KTM 250, so not an of the shelf item. I have an example to be used as a copy.
Regards,
Adrian Goold #101
« Reply #6 on: November 07, 2007, 11:59:05 am »
The amount of metal removed from that sleeve Adrian, it probably resembles a macrame top rather than a bore - more holes in it than george bush's wmd story.
