Author Topic: Repairing Carby Inlet Rubber.  (Read 3630 times)
« on: October 08, 2009, 08:00:01 am »
I was thinking of using Super Glue for this repair. Any comments, experiences or suggestions of a better more appropriate glue?
All Things 414
Re: Repairing Carby Inlet Rubber.
« Reply #1 on: October 08, 2009, 08:12:44 am »
The stuff they use to fit windscreens so I'm told Graeme......... :-\
All Things 414
« Reply #2 on: October 08, 2009, 08:16:41 am »
If I couldn't possibly find a replacement one...... ::)
basil44
« Reply #3 on: October 08, 2009, 08:18:02 am »
Get a tube of Sikaflex, glue it then put it over a pipe the right diameter, leave it for 24 hours and then very carefully remove it (get something under it to cut it from the pipe). It will stay flexible, superglue goes to hard and the clamp will split it. Cheers John.
basil44
« Reply #4 on: October 08, 2009, 08:19:31 am »
Sikaflex is what they glue windscreens with. ;)
« Reply #5 on: October 08, 2009, 08:31:56 am »
Thanks guys, Sikaflex it is then ;) :).
Offline piney
« Reply #6 on: October 13, 2009, 10:01:46 am »
I used sikaflex on mk7 carby boot with a great result
Offline jimson
  • Sanctuary point N.S.W
« Reply #7 on: October 13, 2009, 08:15:15 pm »
MX250 about 6 months ago through out about 7or 8 cartridges of sikaflex I worked for O'brien glass back in the 90s  ::) jimson
TwoTees
« Reply #8 on: October 17, 2009, 08:28:04 pm »
http://polaris.rghonda.com/fiche_section_detail.asp?section=1148&category=Motorcycles&make=YAMAHA&year=1974&fveh=33
I am assuming its off your MX250??
These guys database says they have one for $13.36 US.
Might be worth a try.
Edit: also these guys but they want a little more
http://216.168.60.165/speedandsportinc/Results1.tpl?command=search&db=yamaha.db&bwSKUomdata=364&SKUomsort=1&cart=1220513805317822&max=50&Title=Yamaha%2520Parts.&Switch=search&ViewToken=T
Item 25   $78.55us
« Last Edit: October 17, 2009, 08:33:40 pm by TwoTees »
« Reply #9 on: October 17, 2009, 09:08:38 pm »
This one is off an RT1, part marked 12 - $123.50. I think I'll repair it - it seems it works and be outa sight. Although I'll put my dibbs on that MX one for $13.36 ;) ;D
http://216.168.60.165/speedandsportinc/Results1.tpl?db=yamaha.db&Cart=1220513805317822&max=50&SKUsort=1&SKUsdir=as&skuword=sw&textAword=sw&Switch=SEARCH&Command=Search&ViewToken=T&SKUomsdir=as&bwSKUomdata=284-14453-00-00&wotextAdatarq=&woModeldatarq=&bwSKUomdatarq=&Search=Parts+Search
« Last Edit: October 17, 2009, 09:20:00 pm by mx250 »
