Author Topic: wanted triple clamps 36mm  (Read 2056 times)
« on: October 08, 2009, 07:47:41 am »
would like a set of yz250/400 c 1976 triple clamps but any set would do as long as the forks can slide through without hiting the bars
Re: wanted triple clamps 36mm
« Reply #1 on: October 08, 2009, 08:18:23 pm »
aren't tt500c tripples the same?could widen your chances of finding some and the forks will slide through without hitting the bars
« Reply #2 on: October 08, 2009, 08:23:22 pm »
tt500c arnt the same the bars are mounted further back on the yzc ones
Offline Noel
« Reply #3 on: October 08, 2009, 08:49:15 pm »
Jim,
the tripple's on my XT500D allow the forks to be slid up,
although the bars are mounted on bolt through clamps
but looking at the pictures in my manual the TT one's should allow the forks to slide past the handle bars any way
I'm wondering what you have?
HTH
Noel
« Last Edit: October 08, 2009, 08:54:07 pm by Noel »
Offline Snowy 76
« Reply #4 on: October 08, 2009, 09:27:59 pm »
Jim, might have something will have a look on the weekend.
Couple of CR`s
« Reply #5 on: October 15, 2009, 08:21:46 am »
anyone find a set
Offline motomaniac
« Reply #6 on: October 15, 2009, 09:39:13 am »
You need to post a photo because its not clear what you actually after. I have yz ones for leading axle type forks that allow the forks to slide up past the bars.
« Reply #7 on: October 15, 2009, 06:12:59 pm »
the yz ones are from 1976 it as well 36mm forks not leading axle type
thanks
