Author Topic: 84 Swingarm Bearing Numbers?  (Read 2636 times)
Offline Husabergpete
« on: October 07, 2009, 02:34:38 pm »
Can anyone tell us the code number for the 4 needle bearings which go in the swingarm pivot of an 84 Husky 250.
Ta
Pete
Offline PEZBerq
  • Brisbane
Re: 84 Swingarm Bearing Numbers?
« Reply #1 on: October 09, 2009, 09:58:18 pm »
I used a SKF HK2016-2RS I believe.  Be careful fitting them.  I put them in the freezer and tap them in with a hammer using a socket as a drift.  A little grease in the swing arm helps.  Final installation done using a G clamp to gently push them into the swingarm just far enough so the O-ring seal seats properly.
« Reply #2 on: October 12, 2009, 02:50:51 pm »
Many thanks.
