Author Topic: Pe 250 T Clutch cover  (Read 4048 times)
Offline southnztim
« on: October 03, 2009, 06:08:25 pm »
Does anyone know if a PE 250T has the same clutch cover as a PE 400. Thanks, Tim
Re: Pe 250 T Clutch cover
« Reply #1 on: October 03, 2009, 07:09:43 pm »
NO  not the same   different at locating pins .......but very close
Offline suzuki27
« Reply #2 on: October 03, 2009, 07:21:50 pm »
Not dead sure but I reckon the RM 250T is the same and the PE 175 as well.
DR
« Reply #3 on: October 03, 2009, 08:35:28 pm »
this is in the Parts For Sale section..a maybe perhaps..
2009-08-31 suzuki PE 250 N or T parts camden 46571213 or 0410713454 $ 1.00 No Picture
Have a bike which has been dismantled most parts are there. email [email protected]
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #4 on: October 03, 2009, 08:56:06 pm »
NO. close, but not quite matched. The locating dowel thingies are different.
Do you need for a 250 or for a 400?
« Reply #5 on: October 03, 2009, 10:39:15 pm »
Part # = 11341-40300
Part Description = COVER,CLUTCH
Model Count = 7
PE250T 1980
PE250X 1981
RM250-N 1979
RM250-T 1980
RM250-X 1981
RS250T 1980
RS250X 1981
Offline southnztim
« Reply #6 on: October 04, 2009, 06:17:07 am »
Thanks for the info guys. Unfortunately put a hole through my 250's one. Was hoping,just maybe that the 400's might fit. At least, that list widens the field a bit. Will try that address and keep my fingers crossed. Cheers
« Reply #7 on: October 04, 2009, 07:49:15 am »
Let me see , hole caused by kick lever.
DR
« Reply #8 on: October 04, 2009, 12:19:59 pm »
I've had a 2 part epoxy ribbon type repair in my RM400 case for about ummm..25 years I guess. The poor man alternative ;D Most probably used Selley's cause..it works! ;)
« Last Edit: October 04, 2009, 12:22:40 pm by Doc »
Offline lukeb1961
    • PE175N
« Reply #9 on: October 04, 2009, 12:28:10 pm »
JB Weld is your friend  ;D
Offline southnztim
« Reply #10 on: October 04, 2009, 01:37:34 pm »
Second cover with a hole in it! Coming off on the left side and gear selector shaft punching the stop through the cover. Grrrr
« Reply #11 on: October 04, 2009, 08:11:40 pm »
make sure you install a nylon    bush ( roller on selector shaft ) between seal & gear lever
Some models had a thin ( 3mm ) stopper shaft that had a nylon bush .....   see  Suzuki parts book
http://www.alpha-sports.com/suzuki_parts.htm
go to 1980-  Rm 250  - gear shifting        parts  23 & 27
« Last Edit: October 04, 2009, 08:14:27 pm by oldfart »
