Author Topic: Looking for parts new or old 1983 WR/CR 250  (Read 3853 times)
Offline rtb
« on: September 30, 2009, 11:49:50 am »
Hello Looking for parts on a project i am doing up to go Heaven Racing next year. Can anybody assist me with;
Husky Project 1983 CR 250 Engine No 2088 WR Frame No WO-
Items Needed            Part No
1   Rear brake rod          1515444-04
2   Rear brake spring         1510835-01
3   Front fork seals         1512402-01
4   Front fork air valves      1512346-01
5   Front fork valve caps      1512348-01
6   Front fork covers         1512372-01
7   Swingarm needle bearings      1510607-01
8   Swingarm o-rings         7404810-04
9   Chain tensioner spacer      1515453-01
10   Chain tensioner spring      1515454-01
11   Chain tensioner roller
12   Rear shock ball joints      1510706-01
13   Magura clutch perch complete   1515314-01
14   Magura protector         1513056-01
15   Magura brake perch complete   1515323-01
16   Magura protector         1513055-01
17   Fuel cock            1514056-01
18   Supports            1514091-01
19   Tank Holder         1514060-01
20   Reed valves         1611864-01
21   Reed valve gasket         1611862-01
24   Reed valve gasket         1611861-01
25   Inlet manifold         1611858-01
26   Base Gasket         1611882-01
27   Crankshaft right ignition side      1611659-01
28   Piston kit 70.00mm         1611210-03
29   Big end bearing
30   Needle bearing         1610933-01
31   Spacer            1610971-01
32   Key            1513703-01
33   Silencer            1514548-01
34   Grommet            1614728-01
35   Gasket crankcase right side      1611667-01
36   Flange sleeve crankcase right side   1611516-01
37   Gasket crankcase left side      1611650-01
38   Kickstart rubber         1225702-01
39   Gear lever rubber         1612688-01
40   Kickstart holder         1611848-01
41   Kickstart buffer         1611709-01
42   Cap crankcase left         5011538-03
43   Ignition coil         1614714-01
The list is long but you have to start somewhere.
Many thanks
Offline PEZBerq
  • Brisbane
Re: Looking for parts new or old 1983 WR/CR 250
« Reply #1 on: September 30, 2009, 08:12:42 pm »
These bikes have lots of parts still available.  Almost all bearings are available from any good bearing supplier e.g SKF etc. Swing arm, shock ball joints, O rings, etc.
eBay has heaps of stuff if you are prepared to wait for items to come up.
www.husqvarna-parts.com or www.huskyparts.com.au are also good sources.
Good luck - the resto is well worth it.
Offline DG 26
  • 250H 125D it490 looking for pre75bike
« Reply #2 on: September 30, 2009, 08:15:43 pm »
G,day rbt
Try Husky parts ph95311547  or www.huskyparts.com.au  they have lots of bits?
