Author Topic: seal savers  (Read 7311 times)
Re: seal savers
« Reply #15 on: October 02, 2009, 01:26:27 pm »
sorry Freaky can't resisit the temptation - Geoff I have a photo of Freaky following somebody - should I put it up!!!!!!   ;D ;D
Rossco  :D
Offline Pete Hoey
    • hoey racing
Re: seal savers
« Reply #16 on: October 07, 2009, 09:37:16 am »
You mite as well zipty sand paper to to your forks ;) as dirt gets traped under them it dose the same thing :o
Fork seals are cheaper than rechroming fork tubes!
MONTESA VR
CZ 380
RM125S
WTW
Offline mike1948
  • Margate, QLD
Re: seal savers
« Reply #17 on: October 07, 2009, 10:27:18 am »
I agree.  The less touching the fork leg, the better.  Any large surface area will trap moisture and grit.  Just one days riding can scratch the surface, leading to wear & rust.  I'd just stick to fork sliders, anything which gets through is not trapped against the surface, grinding away.  The surface area of the wiping edge of a seal will not trap grit, and is much cheaper to replace.
Mike
