Author Topic: Source for bar pad foam/rubber  (Read 3653 times)
090
« on: September 28, 2009, 07:41:16 pm »
I want to make a few era bar pads. I can get the cover done but haven't found a source for the foam part.
Any help appreciated.
Re: Source for bar pad foam/rubber
« Reply #1 on: September 28, 2009, 07:51:20 pm »
 no luck at clarke rubber?
or maybe someone who does that protective foam wrapping they do on the aircon pipes?
090
« Reply #2 on: September 28, 2009, 08:16:05 pm »
No mate. All there stuff was wrong size or compound.
« Reply #3 on: September 28, 2009, 08:25:20 pm »
what about buying some cheapo bar pads off ebay, ditch the covers and then you have the foam  ;)
Offline pmc57
« Reply #4 on: September 28, 2009, 08:58:48 pm »
Brad
Can't be certain if this will do the job, but what about refrigeration insulation, the stuff they use on airconditioner pipes? It's made to slip over pipes so it has lengthways slits and comes in lenghts of about 1.5 - 2 meters, all you need to do is cut to length.
Pete
Offline frostype400
« Reply #5 on: September 28, 2009, 09:02:59 pm »
oh yeah that might work 1/2 inch armaflex it is called can buy it from reece/tradelink etc etc plumbing supplies also they have it in solar proof which just has a black covering on top which may be the go as well thanks Michael. :)
1971 tm400 and PE's
090
« Reply #6 on: September 28, 2009, 09:37:44 pm »
Thanks. I will try those sources. Last resort will be to buy cheapies .
« Reply #7 on: September 28, 2009, 11:50:33 pm »
Plumbers lagging, works a treat and seems to be more tear resistant
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #8 on: September 29, 2009, 02:27:24 am »
kiddies swimming pool "noodles" ;D
well it's worth a shot hey...
"flat bickie"
« Reply #9 on: September 29, 2009, 05:57:48 am »
I forgot to mention that I was typing in invisible ink, and you had to rub some lemon juice on your screen ;D
I like Vandy's idea anyway, I'm pretty sure that back in the day Mikkola was sponsored by Swimsafe for his bar noodles
Offline vandy010
« Reply #10 on: September 29, 2009, 09:12:52 am »
whats in that breaky cereal of your Paul? :D :D :D
"flat bickie"
