Author Topic: YZ 125 A B C X swingarm bushes.  (Read 8104 times)
Offline matcho mick
    • Moto Tumbi
Re: YZ 125 A B C X swingarm bushes.
« Reply #15 on: September 30, 2009, 09:47:45 pm »
yeah mate!,shiploads faster than me :D, :P
« Reply #16 on: October 01, 2009, 10:49:53 am »
Slight Diviation but are the twin shock Dt 175 swing arms the same as the YZ125a ?  IF i put them side by side they do but maybe i need glasses.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #17 on: October 01, 2009, 11:27:49 am »
are you talking about the bushes or the swing~arms?
not too sure about the bushes but i have a DT125c and DT100a and both swingarms are the same as each other but are HEAPS DIFFERENT to my MX125a swingarm.
my MX125a swingarm is longer and wider at the pivot point than the DT swingarms.
i'd suspect the YZ125a swingarm to be the same as the MX.
basically, the YZ/MX frame is "wider" at the swingarm pivot point.
i think you'll find the left/side engine case on the YZ/MX is also "wider" by the same amount and the countershaft is "wider" as well.
theres only about 7mm~ish {can't remember exactly} in it.
"flat bickie"
« Reply #18 on: October 01, 2009, 02:45:36 pm »
YOur going to make me pull them both apart arent you ?
One of the YZa has a ugly brace weld and i have a wrecker 175 here and the swing arm looked similar, though it might be an easy swap/repair job.......
