Author Topic: DT 360A  (Read 2310 times)
MTSEAN
DT 360A
« on: September 25, 2009, 03:57:38 pm »
I am having trouble finding a rod and/or rod kit for my 360. Have recently found pistons and crank seals with quite a bit of searching.  I would appreciate anybodys help or guidance as I have exhausted a lot of options including pro x and sirco.  I really need to find a genuine one if possible.
shanefz6
Re: DT 360A
« Reply #1 on: September 25, 2009, 04:22:25 pm »
Yamaha Part Num 24Y-11651-01  $142.60 RR. Has to come from Japan 2-3 weeks.
Its the Rod that i'm running in my RT1
« Last Edit: September 25, 2009, 04:28:21 pm by shanefz6 »
MTSEAN
Re: DT 360A
« Reply #3 on: September 26, 2009, 08:19:51 am »
cyclegod i hate to doubt your advice but are u sure that is the same rod before i buy it
Re: DT 360A
« Reply #4 on: September 26, 2009, 01:26:53 pm »
I think he is right - I can't find it but we had another thread here on suitable rods before  - (will keep looking) - as I think it was an 83/89 YZ250 rod I put in my YZ360.
Will see what I can dig up.
Rossco
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: DT 360A
« Reply #5 on: September 26, 2009, 01:34:45 pm »
the 214 rod {DT/RT1,2,3 YZa/b 250/360} is different to the
     311 rod {DT/MX250/360a}
i just scored a N.O.S. rod to put into my MX250a. had to get the shims,bearing & pin seperately.
it all cost a bit more than i'd hoped but it's all ready for instalation and soon to be back on track again.
check if you can whether the big end pin is 24mm or 25mm and a good yamaha parts guy can sniff one out.
short for time right now but will post some more info when i can.
"flat bickie"
Re: DT 360A
« Reply #6 on: September 26, 2009, 01:43:38 pm »
there ya go - just found the thread from September 07 - "1974 Yamaha YZ360B" - and the person who sprung to mind was Vandy!!!!!
Rossco
MTSEAN
Re: DT 360A
« Reply #7 on: September 28, 2009, 07:02:55 pm »
Thanks for your help guys . Because of your advice I have been able to source all parts.
