Author Topic: wanted yz triple clamps for tt500  (Read 2665 times)
« on: September 25, 2009, 10:03:16 am »
wanted set of pre80 yz400/250 triples to put on my tt500 so i can slide forks through for dirt track
jim
Offline yamaico
Re: wanted yz triple clamps for tt500
« Reply #1 on: September 25, 2009, 12:34:55 pm »
Jim,
What diameter are the fork tubes?
« Reply #2 on: September 25, 2009, 12:57:36 pm »
76 -78 TT500 or 78-79 XT500 triples will also do what you want, im pretty sure the IT/TT/YZ triples are all the same for the 36mm non leading axle forks anyway.
« Reply #3 on: September 25, 2009, 01:53:31 pm »
pre 80 yz250/400defg were fitted with 38mm forks,yz125/it175defg and leading axle equipped tt/xt500 were fitted with 36mm forks so what do you need as ive got both sets of tripples
TT5 Matt
« Reply #4 on: September 25, 2009, 02:25:20 pm »
what i heed is a set of triples that fit std xt500 non leading axle forks.i need to be able to be able to push forks about 50mm through and also have rear facing handle bar clamps like the yz400
jim
« Reply #5 on: September 25, 2009, 02:45:39 pm »
So you need YZ125X triples.
But it gets more complicated: The 125X triples hold the fork legs closer together than the TT triples do, so I think you also need a matching brake plate (from a YZ250A~C, MX250, or YZ125C/X), and I'm not 100% sure about the lug on the TT/XT fork leg.
Offline brent j
« Reply #6 on: September 25, 2009, 04:55:35 pm »
Have a look in the Ballards catalogue, they have an offset bar riser.
It will lift the bars by 20mm or so but it will also allow you to move the bars back by about 50mm.
Brent
« Reply #7 on: September 25, 2009, 08:38:17 pm »
ive only got one set of that style tripples reserved for a xt500d
