Author Topic: Opinions on 1982 YZ 490  (Read 5197 times)
Offline mitch75
  • Newcastle NSW
« on: September 23, 2009, 09:11:36 pm »
Want to know the good and the bad about the 1982 YZ 490.
Yamaha DT360a DT250b DT100c YZ400D WR250ZG.
Re: Opinions on 1982 YZ 490
« Reply #1 on: September 23, 2009, 09:17:15 pm »
let the fun begin.
I rode one back in 82' didn't think it was so bad (i had the same model 250). heres my take
if you want to race pre 85, there are a lot better choices around, if you just want a bike to ride VMX they are fine.
dave
« Reply #2 on: September 23, 2009, 09:37:00 pm »
BEWARE they are DANGEROUS!!!! and if you know someone with one tell them I'll come over and remove it from their property immediately before it causes damage!
Offline mitch75
  • Newcastle NSW
« Reply #3 on: September 23, 2009, 10:57:00 pm »
Nice one dave and i guess it would be kept in your shed for the safety of others.
« Reply #4 on: September 23, 2009, 11:14:40 pm »
This is a prototype bar stall for YZ490 riders but was rejected as being 'too small' :o.
lms6201
« Reply #5 on: September 24, 2009, 05:31:39 am »
i,d want a bit more space in that chair , not the most competitive but like back in 82 can be improved , are cheap to keep running and easy to get major parts for ,solid tranny , people say they ping a bit but can be jetted a lot better , chances if it is a runner it would have been done , maintainence on the rear end is a must with the j to keep it tracking , they like to swap ends at speed , forks can be improved and 43mm kayaba bits are common ,  the  k is a far better handling bike and overall should be a better choice , as it turns out i could spare a pair of 490k,s
hotdog1975
« Reply #6 on: September 24, 2009, 06:52:19 am »
rebuilt a 490J approx 5yrs ago & now sold - doh
they do ping when hot - do the head mod & jet correctly
use valve grinding paste on the flywheel taper to lap it in & apply a drop of loctite on reassembly - otherwise it will shear the key
most bits are available inc a/market plastics - maier etc
Offline pirie593
« Reply #7 on: September 24, 2009, 06:18:51 pm »
Was there an I model  ???
« Reply #8 on: September 24, 2009, 06:50:00 pm »
No I model. The J's weren't that good compared to the K model and the L is better again.
Offline pirie593
« Reply #9 on: September 24, 2009, 06:55:42 pm »
Do the K or L models qualify for twin-shock racing in the UK?
Is the J model better than the G or H model?   ???   ???
lms6201
« Reply #10 on: September 24, 2009, 08:07:00 pm »
when u say(or ask)if it is  better , do u mean is it better than the previous model ( i guess all manufacturer,s try to make a better model every year )or is it better against it,s competition ?  and as for twin shock in the uk what is it based on ? our evolution class ?
colmoody
« Reply #11 on: September 24, 2009, 08:14:21 pm »
JohnnyO can you tell me what the difference is between 490 K and L and which year models are which. Bought one secondhand  in the mid eightys. Think it was an 84 model. Had a red seat from memory and had done bugger all work. Had big plans for it but you can guess the rest.
It's about last weekend JohnnyO. Whats your story.
« Reply #12 on: September 24, 2009, 09:01:23 pm »
Too many local motocross races been on.. can't afford to go to everything.
The '84 L model has a new frame with a centre port exhaust and the pipe on the right instead of side port and pipe on the left side. L also has new cylinder with 8 petal reed replacing 6 petal of earlier models. The J, K and L all have different plastics.
