Author Topic: CR480 Sag  (Read 4239 times)
Offline Tahitian_Red
  • Mugen ME480
CR480 Sag
« on: September 20, 2009, 07:44:26 am »
What sag setting do you run your CR480's at?
It seems the stock springs and most aftermarket springs are made for someone under 190lbs (86Kg).  I'm having trouble getting to the 100mm recommended race sag without losing the static sag.
The "Factory Novice"
California, USA
090
Re: CR480 Sag
« Reply #1 on: September 20, 2009, 08:22:19 am »
Sounds like you need a heavier spring. I need to sort mine as well as it tends to squat under acceleration.
Offline caps 999
Re: CR480 Sag
« Reply #2 on: September 20, 2009, 09:32:15 am »
and for fox shocks for the 480
MUGEN power
Offline motomaniac
Re: CR480 Sag
« Reply #3 on: September 20, 2009, 11:01:08 am »
We hade a few requests lately to replace springs or shocks for that model. However , I believe the OD of the spring has to be narrower than standard springs , to clear the airbox . If there is a firm demand ( preorders) we will make a special limited  run of them .
Thats right .The shocks are only 40mm ID so the whole thing including the spring is abit narrower than the later model stuff .They went to a 44 in 84 for thr 250 and a year later for the 500's (I think) 46 mm a few years later 88 I think.
Also the 450 b and 480 C has a lot harder spring rate than the 480 D.
090
Re: CR480 Sag
« Reply #4 on: September 20, 2009, 11:57:54 am »
I bought a spring over the counter at a bike shop. I think it was an Eibach .
http://eibach.com/cgi-bin/htmlos.exe/07334.1.3876691793500025080
  • Mugen ME480
Re: CR480 Sag
« Reply #5 on: September 20, 2009, 01:21:56 pm »
The Eibach spring that works for the stock shock is 883.0067.1.  It is a 6.7Kg/mm spring and works for folks over 86 kilos.  I have an Ohlins shock and the highest spring rate I can get is 6.4Kg/mm.  I guess I'm gonna have to work on the other side of the equation and lose weight.
 ;D
California, USA
Offline motomaniac
Re: CR480 Sag
« Reply #6 on: September 20, 2009, 01:46:48 pm »
 ;D
But is your s  C or a D ? Big diff in spring rates .A guy in VIPER got a 7.7 kg Eibach for his C.
  • Mugen ME480
Re: CR480 Sag
« Reply #7 on: September 20, 2009, 02:30:50 pm »
 ;D
Sorry about that.  I only have 1983 CR480's, so it would be for a D model.  ;)
California, USA
Re: CR480 Sag
« Reply #8 on: September 20, 2009, 04:46:01 pm »
just slightly off topic about the bike but definiately about springs (which I know nothing about but getting there).  The spring rates you mention are really really high for what I am aware of???  My 360B has a 4.0 kg rate spring and I have beenn chasing a 4.2 as I am a "little" over the 86 kg mentioned here but this is way short of what you are mentioning.  I know the shocks are entirely different but is the shock rate a fairly relative thing ie is 4.2 way too low for what I would be after?
Rossco
Offline caps 999
Re: CR480 Sag
« Reply #9 on: September 20, 2009, 04:57:49 pm »
on the 480 because the swing arm is such hight leaverage you need to run an extreamly heavy spring
MUGEN power
Offline motomaniac
Re: CR480 Sag
« Reply #10 on: September 20, 2009, 05:31:28 pm »
caps its more to do with the linkage set up .81/82/83/84 Hondas have pretty much the same length swingarms ,same overall bike weight , similar motors and power etc but 81/82 480 has a 7.7 kg standard and a 8.2 kg optional spring.83 has a different linkage and leverage ratio .Spring rate is 6.0 kg and 6.4kg opt. 84 is different again and has a 4.5kg spring (although way too soft ,should be 4.8 standard)
Offline motomaniac
Re: CR480 Sag
« Reply #11 on: September 20, 2009, 05:33:23 pm »
if you want them , we will make them . Just nominate the rate desired.
How much for one of spring?
