Author Topic: 38mm Mikuni or bits needed  (Read 1644 times)
dave
« on: September 16, 2009, 08:45:45 pm »
I've got a stripped 38mm Mikuni for an IT250H/J which is missing bits (most bits!) I need;
- slide spring
- adjuster screw/pipe that goes into the top plus the assorted hardware
- float
*main jet #400
*pilot jet #50
- the plate under the main jet
- the brass ring
Or a complete 38mm Mikuni
Cheers Dave
« Last Edit: September 16, 2009, 08:49:49 pm by dave »
Offline oldyzman
  • 250 two stroke!
Re: 38mm Mikuni
« Reply #1 on: September 16, 2009, 08:52:43 pm »
Hey Dave, A while ago i was looking for a carb for my YZ, South west sydney motorcycle wreckers on homepride ave at liverpool, had a 38mm but it was off an IT, a bit different to the yz as it had a brass float opposed to plastic twin floats,
I was lucky to get a yz 250 F '79 one from Nathan...
Brett
dave
Re: 38mm Mikuni or bits needed
« Reply #2 on: September 16, 2009, 08:58:21 pm »
Cheers I'll try ringing them. Did they want lots for it?
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: September 17, 2009, 09:19:00 pm »
Mate they wanted thirty dollars for it. it was cheaper than the others as it did not have a cable and throttle attached to it, as most of the others in that wreckers do.
« Reply #4 on: September 21, 2009, 04:32:32 pm »
haven't got them yet (parts that is) and I must admit the phone "etiquette" was pretty ordinary but you could also try www.mikunioz.com.
Rossco
