Author Topic: swinging arm  (Read 1884 times)
Offline paco
swinging arm
« on: September 16, 2009, 04:36:01 pm »
Can some body explain,what exactly wears on a swingarm? Where is the free play comming from?How do you make measurements if you were going to make  new swingarm bushes.
what ! Who me ? Nah
DR
Re: swinging arm
« Reply #1 on: September 16, 2009, 08:26:31 pm »
I can explain what wears, pivot bolts, the inner bushes/sleeves, the bearings or outer bushes and in some extreme cases the swingarms themselves get flogged out around the bearing which also creates play(usually on the left or drive side). Not knowing what bike it is I'd say the best bet for the bronze bush sizing would be buy an original bush or get the original bearing size and have it copied.
Re: swinging arm
« Reply #2 on: September 17, 2009, 04:50:08 pm »
And while you have it out fit a grease nipple approx center of pivot ...... making sure it clear engine cases when suspension is comperssed
Offline paco
Re: swinging arm
« Reply #3 on: September 18, 2009, 04:27:41 am »
thank you for the helpfull advice.The bike is a bultaco alpina.I also have a metralla,the bushes look very much the same.I will get some sets made up. Inner and outer bushs',swing arm bolt]and I'll be sure and fit a grease nipple.Thanking you,paul.
what ! Who me ? Nah
