Marketplace
Wanted
IT250H/YZ250 Bits
Topic: IT250H/YZ250 Bits (Read 2113 times)
dave
IT250H/YZ250 Bits
September 15, 2009, 07:08:02 am »
I'm after a variety of bits for my IT250H and a YEIS bottle plus joiner pipe into the manifold is one of them. I'm also after a carbie for it and these bits;
*front brake hub backing plate
*gear shifter shaft
*front chain guide (front of swingarm)
*swingarm bearings/bushes
*front sprocket cover
*whole carbie or carbie slide spring/pilot jet/main jet/float
*conrod kit
*1.50mm OS Piston Kit
*cables (throttle/clutch/front brake)
*all engine oil seals and gaskets
Thanks Dave
Viper666
"Yes I bought THAT number plate" so sue me!
Re: IT250H/YZ250 Bits
September 15, 2009, 07:15:54 pm »
Most of that stuff is available from Yamaha dealers.
*front brake hub backing plate Ebay or wreckers (Single leading edge) Do you want the speedo drive?
*gear shifter shaft Should be avail from dealer but can weld new end on
http://cgi.ebay.com/ebaymotors/83-YAMAHA-YZ250-YZ-250-TRANSMISSION-GEAR-SHIFT-SHAFT_W0QQitemZ370246462125QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item563468aaad&_trksid=p3911.c0.m14
*front chain guide (front of swingarm) On ebay all the time but I bought from dealer Yamatopdog (Speed & Sport USA)
*swingarm bearings/bushes Dealer (Expensive) Ebay or Yamatopdog
http://216.168.60.165/speedandsportinc/index.tpl
http://www.x-tremevintageyz.com/products.php
*front sprocket cover Same as YZ, Ebay
*whole carbie or carbie slide spring/pilot jet/main jet/float Ebay
*conrod kit Definitely avail from dealer
*1.50mm OS Piston Kit Wuseco from dealer about $150-$175
*cables (throttle/clutch/front brake) Ebay or dealer
*all engine oil seals and gaskets Dealer
Use this link to chase part numbers
http://www.yamaha-motor.com/sport/parts/home.aspx
Viper666
Last Edit: September 15, 2009, 08:53:30 pm by Viper666
YZ80H, YZ100G, YZ125E, YZ125F, YZ125G, YZ250D, YZ250E, YZ250F, YZ250G, YZ250H, YZ400F, IT125G, IT250K & a, a, a, CRF250X?
Viper666
September 15, 2009, 08:17:24 pm »
Bottle
http://cgi.ebay.com/ebaymotors/83-YAMAHA-IT250-YZ250-INTAKE-AIR-CHAMBER-BOOST-BOTTLE_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem1c082a7da1QQitemZ120396086689QQptZMotorcyclesQ5fPartsQ5fAccessories
Shift shaft
Last Edit: September 15, 2009, 08:24:13 pm by Viper666
dave
September 15, 2009, 08:57:29 pm »
Thanks for the tips. I knew I could get these bits new. Just thought someone out there might be looking to offload old/new spares etc. Hey Viper have you dealt with X-TremeVintageYZ.com before? How long does it take to get bits?
Viper666
Reply #4 on:
September 15, 2009, 09:09:35 pm »
Yes and they are good to deal with, their singarm kits are quality parts. Haven't bought other stuff but they have a good rep.
Viper666
Viper666
Reply #5 on:
September 15, 2009, 09:44:34 pm »
This might help
http://www.yamahait.com.au/manuals.html
DIRTPILOT72
A-Grade
Reply #6 on:
September 15, 2009, 11:26:10 pm »
I can get throttle, clutch, speedo cables. Full gasket kit, all bearings except swingarm, chain and sprockets, chain rollers. Pm me if you interested.
Honda XR200 x2
Honda XR250
Yamaha Yamahopper QT50
Marketplace
Wanted
IT250H/YZ250 Bits
