Marque Remarks
Honda
Honda powered Deckson mini
Topic: Honda powered Deckson mini (Read 1689 times)
Quicksilver
September 13, 2009, 04:55:17 pm »
I am building a very quick little Honda powered deckson
The little rocket should go quite well with Odyssey engine which uses 250 Elsinore head and barrel.
I am looking for a clutch from Honda Odyssey (4 wheel Honda buggy) made in the early 1980's. Also pipe for same. Clutch uses fairly wide belt as seen in the attached picture of engine drive.
matcho mick
Re: Honda powered Deckson mini
September 13, 2009, 08:10:50 pm »
err,isn't it in the dome sorta?,i thought it was centrifugal drive depending on engine revs for go motion ,that would work? & also just vary gearing up
Quicksilver
September 13, 2009, 09:06:13 pm »
I Shoulda worded my post better. Clutch belt drive on the "axle" side not the "CENTRIFUGAL" as anyone can quite clearly is on the engine already.
Marque Remarks
Honda
