Clubroom
Tech Talk
what year is my rm125 ?
Topic: what year is my rm125 ? (Read 3130 times)
kkj2009kkj2009
September 11, 2009, 05:50:13 pm »
I have recently bought a rm125 as a project but cant figure out what year it is, to me the engine looks like an 84 but the frame looks like an 81-83 because the shock cannister is mounted on the left hand side below the fuel tank.
the frame number is rm125-208688
engine number rm125-216162
can anyone make sense of these numbers
DR
Re: what year is my rm125 ?
September 11, 2009, 08:04:42 pm »
I 'think' it's an '81, both numbers seem to corrospond to this model. From the '83 D model I 'think' (again) the eng and frame numbers had the prefix RF11,RF12,RF13 and so on..
DR
September 11, 2009, 08:07:53 pm »
http://jb4oia.bay.livefilestore.com/y1puCnw-XFJcyTOzaKph_eo9JUx9Ias_9f6EuRPA6SkKR1fnYPKw55lRdh3Go669EF4RttYF8_dJutfNDEG79fkpg/Suzuki%20Chassis%20Number%20List.jpg
http://cid-86267c09a3452a71.skydrive.live.com/self.aspx/Vintage%20Suzuki%20General%20Technical%20and%20Specifications/Suzuki%20ID%20all%20models%201970-2004.pdf
see if you cn make some sense of them
kkj2009kkj2009
September 11, 2009, 08:11:27 pm »
it has the reed valve underneath the barrel instead of being bolted to the outside of the barrel if that helps, and the clutch linkage is on the left hand side.
kkj2009kkj2009
September 11, 2009, 08:32:56 pm »
looking at them numbersthe frme would be an 81 model which is a rm125x but im not sure about the engine
kkj2009kkj2009
September 12, 2009, 10:19:59 pm »
would photos help anyone? ? ? ? ?
frostype400
September 12, 2009, 10:21:55 pm »
perhaps post them up
1971 tm400 and PE's
DR
Reply #7 on:
September 12, 2009, 10:29:03 pm »
wouldn't help me sorry but others who have these models would recognize any discrepancies or differing model parts..post some pics
suzuki43
Reply #8 on:
September 13, 2009, 06:18:30 am »
Its sounds like a 1981 x to me.
kkj2009kkj2009
Reply #9 on:
September 13, 2009, 06:29:25 pm »
well i would have taken photos but the bike is in pieces now, im pretty sure its an 81 but not 100% on the engine being an 81
suz125
C-Grade
Reply #10 on:
September 13, 2009, 11:08:26 pm »
if you post up pics of the barrel it should becom clear on the engine which model it is
caps 999
Reply #11 on:
September 14, 2009, 09:21:51 pm »
you have a rm125x frame with a z motor by the looks of it
MUGEN power
RMJJ
Reply #12 on:
September 16, 2009, 12:41:11 am »
1981 engine has case reed and two bolt holes for front engine mount and bolt on head water outlet
1982 engine has full reed and one bolt hole front engine mount and cast in head water outlet
1983 is same as 1982 externaly but has F106 engine number not RM125
1984 engine is similar to 1981 but not RM125 engine number. Has case reed but cast head water outlet
you have got and 81 or 82 motor, check it against the description above.
kkj2009kkj2009
Reply #13 on:
September 16, 2009, 05:53:09 am »
definately number 1
Clubroom
Tech Talk
