Author Topic: IT/YZ250H fork damper rods  (Read 1593 times)
dave
« on: September 08, 2009, 06:01:48 pm »
I know that Terrykits (USA) used to make an IT250 swap over damper rod kit to get 12" of travel out of the IT forks. Anyone know any tricks for swapping any YZ damper rods to get the same effect? Cheers
Offline rocketfrog
Re: IT/YZ250H fork damper rods
« Reply #1 on: September 09, 2009, 02:58:20 pm »
I think you will find that the IT has 38mm Forks up to 83 at least, while the YZ (h) has bigger dia. Try looking at YZ 250G for a more compatable change over, they were 38mm for sure.
Offline motomaniac
« Reply #2 on: September 09, 2009, 05:12:33 pm »
WHAT DIAMETER ARE THEY?IT'S HAD 36MM FORKS UPTO 1980 AT LEAST IM NOT SURE ABOUT 81'S. YZ250/400 WERE 38MM UPTO 1980 ,125 WERE 36MM UPTO 80?.81 250/465 ON WERE 43MM , 125 HAD 38MM TO 83
« Last Edit: September 09, 2009, 05:17:37 pm by motomaniac »
