Author Topic: Pe speedo and bracket  (Read 3402 times)
Offline frostype400
« on: September 07, 2009, 04:50:10 pm »
I am really in need of one PE speedo bracket 80-82 models the one that just bolts to the triple trees not front numberplate i would like more than 1 but 1 gets me out of trouble also after all types of PE speedos and the other brackets thanks alot Michael. :)
1971 tm400 and PE's
Offline suzuki 400
Re: Pe speedo and bracket
« Reply #1 on: September 12, 2009, 02:56:59 pm »
have a spare usa speedo bracket that takes the trip style meter , Rod
Offline frostype400
« Reply #2 on: September 12, 2009, 05:47:24 pm »
Hi Rod thanks for that although i do need it for the speedo type to fit the speedo other wise you have to drill and carry on so it would be better with the usa trip on it thanks alot Michael. :)
1971 tm400 and PE's
Offline suzuki 400
« Reply #3 on: September 12, 2009, 08:01:31 pm »
it took me about 5 years to get a nos speedo and another good working version and im sure you know the pe site in aussie they may have a drawing with exact dimensions and bends etc to make one ,good luck
TwoTees
« Reply #4 on: September 12, 2009, 09:03:32 pm »
Frosty,
Do you have a picture of what the speedo should look like?
I'm curious because I have a 1981 TF100 speedo with bracket and from the pictures I've seen of PE's it looks close.
Offline frostype400
« Reply #5 on: September 12, 2009, 09:59:35 pm »
yeah i do pe has a brown face that goes to 160km th e bracket bolts straight to the handlebar clamps and is only held by the to handle bar clamp bolts it is short with two holes in it for the speedo who knows maybe you have a pe speedo on it thanks Michael.
i need the short brackert next to it it was a trip one but had holes drilled for the speedo thanks Michael.
1971 tm400 and PE's
