Author Topic: DT360 problem  (Read 2976 times)
MTSEAN
DT360 problem
« on: September 04, 2009, 10:08:57 pm »
 I am having troubles finding a 80.5 piston for my 73 dt360 standard being 80.  I do have several options ie adapting some other piston of similar specs or finding a nos barrel as it is still easy to find standard pistons or reslieving my barrell [bit costly that one].  One other option is to find an MX 400 barrel as wiseco still can supply piston and rod kits for them.  Only problem is i don't know if the 400 barrell bolts straight on.
 I really would like any help or advice about this problem as i recently had a taste of short circuit at nepean on a borrowed ts400 and am building this bike to have a go.
Re: DT360 problem
« Reply #2 on: September 04, 2009, 11:17:29 pm »
The DT400 top end won't fit, Sean.
Prety sure that RT2 and/or MX360 pistons will also work, which might open up your options.
Offline PCMAX
Re: DT360 problem
« Reply #3 on: September 05, 2009, 05:43:17 pm »
cyclegod, aren't the 0.25mm pistons going to slap around a bit in his 0.50mm oversize barrel?
Offline ty4
Re: DT360 problem
« Reply #4 on: September 05, 2009, 06:02:59 pm »
i have dt360 0.5 piston only,no rings
tony
MTSEAN
Re: DT360 problem
« Reply #5 on: September 05, 2009, 08:03:58 pm »
tony
          I would like to buy that piston of you tony if your willing to part with it . please let me know as soon as you can as i have lined up an mx360 one in the states and will have to get out of the deal . thanks for noticing my dilema
