Author Topic: tm piston  (Read 1825 times)
juzze
tm piston
« on: September 04, 2009, 08:55:32 pm »
Hi im just trying to get hold off a piston for my tm125 1974 model it has a honda m1 piston at the moment  which is 020 bigger than standard.
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: tm piston
« Reply #1 on: September 04, 2009, 09:42:19 pm »
If you want one that is the same size that you have now (.020" = 0.50mm over standard (56.5mm)) see below...
http://cgi.ebay.com/ebaymotors/73-75-SUZUKI-TM125-K-L-RM125-M-PISTON-50-OS-NOS-NEW_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem56303fdbb6QQitemZ370176678838QQptZMotorcyclesQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Suzuki-TS125-Ring-Set-Oversize-0-5_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem3c8e2c99cdQQitemZ260083325389QQptZMotorcyclesQ5fPartsQ5fAccessories
If you want a larger oversize 0.75mm-2.0mm (.030-.080) then you can fit TS/DS/TF125 pistons made by PRO-X, available in 0.25mm increments, however the skirt length is 5mm longer than the TM piston but I have been told this does not have much effect on the TM.
Ban BLACK rims NOW
