Author Topic: XR Fork tubes into a YZ?  (Read 1946 times)
TwoTees
« on: September 04, 2009, 04:52:50 pm »
Hi all,
I am needing some decent fork tubes to complete a yz80d project I've had going for some time. It has 27mm tubes and was curious to know if 27mm tubes from an xr80 will fit or fit with some minor modification, into the YZ lowers.
Cheers, Chris
« Last Edit: September 04, 2009, 04:55:58 pm by TwoTees »
Offline jimson
  • Sanctuary point N.S.W
Re: XR Fork tubes into a YZ?
« Reply #1 on: September 04, 2009, 07:37:19 pm »
G'day Twotees my son has a GT80 & it has postie forks in it cheap from the tip and gives a better turning circle  ;D jimson
Offline BETRIC
« Reply #2 on: September 04, 2009, 11:48:30 pm »
XR80 fork tubes fit but they are to short compared to a YZ80D, try late model (80/81) MX100 forks as they are the same as YZ80D forks, YZ80A/B/C have shorter tubes than the D but the lower legs are all the same, late 77 XR75 to 82 XR80 have a longer lower fork leg, 73/76 XR75 have same length lower legs as YZ80's, XR's from 73 to 82 use the same length fork tubes
DELTEK, 72 MINI TRAIL, 73/4 XR75, 77/78 XR75, DG MONOSHOCK FRAME XR75, REDLINE FRAME XR75, PK RACING MONOSHOCK FRAME XR75, JWRP XR FRAME, SL70K1, 81 CR80RB, TY80A/B, YZ80A/B/D, GT50/80A, GTMX80A, 73 GTMX, GT1, COOPER MX, COOPER ENDURO,MX360A,MX250B,YZ125X MX100, 72 XL250, TC100,TL125, TY250C,IT250J
TwoTees
« Reply #3 on: September 05, 2009, 12:20:45 am »
Beric,
Thanks, you know your hondas. I'm thinking of these.....
http://cgi.ebay.com.au/Honda-xr-80-xr-100-crf-80-100-forks_W0QQitemZ290346180140QQcmdZViewItemQQptZAU_Motorcycle_Parts_Accessories?hash=item4399fb1e2c&_trksid=p3286.c0.m14#ht_500wt_1182
2005 model crf80/100. Do you know if these are longer?
I'm actually not to fussed if it sits a little lower in the front because I think the D looks a little long in the front anyway. Do you think they (earlier type you mention above) would be longer than A B and C? Somewhere in between would be nice.
