Author Topic: CR250M  (Read 3102 times)
CR250M
« on: September 02, 2009, 10:38:16 pm »
Found a Cr 250 today, dont know much about it other then these are its numbers, no idea of year, front brake dont look right though as its a full width hub on 4 bolt clamp fork.
tank is silver with a orange stripe ( which i thought was MT or XL) its twin shock yada yada yada, anyone interested and what sort or price ?
Probally worth it for the engine ( turn over ok and was running) and rear wheel, tank is good, rest is just average or below.
cr250m -2000466
Cr250 ME - 2000501
any info appriciated, sorry dont have a pic up atm
« Last Edit: September 02, 2009, 10:40:07 pm by Freakshow »
Re: CR250M
« Reply #1 on: September 02, 2009, 10:45:02 pm »
that do you want for it freaky i could do with some spare parts cant have too much you know.send me off some pics and a price
jim
Offline Noel
Re: CR250M
« Reply #2 on: September 02, 2009, 11:06:37 pm »
Up pipe or down,
which side of the down tube does the exhaust port exit.
engine no sounds like  M1 '75
http://www.motorera.com/honda/h0250/cr250m/cr250m.htm
Noel
« Last Edit: September 02, 2009, 11:09:58 pm by Noel »
Re: CR250M
« Reply #3 on: September 03, 2009, 12:56:04 am »
had an up pipe but im not sure what on this bike is original.    that web site is a bit pissy , the numbers are arse up.
Im sure the tank is steel with a alloy screw cap, frame may have been black but now is that orange colour, maybe its a 76 ? still the front end look wrong, both front and rear brakes had these strange almost flimsy hollow rod looking brake stays.
Offline TeeBone
Re: CR250M
« Reply #4 on: September 03, 2009, 06:12:30 am »
That's NOT a Honda front end on it then!
Re: CR250M
« Reply #5 on: September 03, 2009, 06:24:42 am »
the forks are different but look the same as 73/74 on the 75/76 wheels are the same though
Re: CR250M
« Reply #6 on: September 03, 2009, 07:30:58 am »
Sounds like a '75 CR250m1 going by those numbers, with a different front brake. They had an alloy tank with a red stripe, up pipe and a black frame and also had a full width front hub and 4 bolts clamping the front axle. Does it run now?
Re: CR250M
« Reply #7 on: September 03, 2009, 11:26:58 am »
yep front wheel was full width  and the forks have four bolts on the axle clamp under nearth ( looked very pre 70 tech to me)
tank was silver orange stripe but looked steel not alloy ( except the screw on capwas alloy for sure)  frame was red, but may have been painted at some time, no side plastics, has seat thought.  Motor was running before parked years back, i can kick it through so the motor should be fine ( no binding)
Probally say its worth whatever the motor is worth ? and i have no idea on that.... offers ?
Re: CR250M
« Reply #8 on: September 03, 2009, 11:34:12 am »
Does it look anything like this freaky..........
http://www.vintagefactory.com/1975_honda_cr250m1_elsinore.htm
Re: CR250M
« Reply #9 on: September 03, 2009, 01:08:27 pm »
YEp thats it.
but not same shiny tank (id say steel like an Xl or MT)
Fork same but front wheel not.
Rear wheel is, remeber that stupid little tubed stay.
motor looks the same
Re: CR250M
« Reply #10 on: September 11, 2009, 05:28:12 pm »
has tank etc in a box, but hats about the size of it in the picture
Offline caps 999
Re: CR250M
« Reply #11 on: September 11, 2009, 06:57:24 pm »
freaky im intrested pm sent
MUGEN power
