Author Topic: DT100 or MX100 80's models - Help required  (Read 1872 times)
subanator
« on: September 01, 2009, 01:05:51 am »
Anyone got a 80's model DT100 or MX100?
I need someone to measure the crank taper and shaft length to the flywheel etc.
I can explain in detail if you are able to help.
Cheers, Roger
Re: DT100 or MX100 80's models - Help required
« Reply #1 on: September 01, 2009, 07:30:22 am »
I have an 88(?) AG100 motor with the ignition removed, if it helps?
subanator
« Reply #2 on: September 02, 2009, 01:37:08 am »
Nathan, that model is still based on the CT1 engine, mine is the mid 70's twinshock but different. Thanks anyway.
