Author Topic: YZ125 B Tank  (Read 8268 times)
Offline motomaniac
Re: YZ125 B Tank
« Reply #15 on: September 01, 2009, 03:07:31 pm »
Another reason that you don't see them Firko is that they went Elsinore mad  in the US  and since the B was just a A painted yellow it didnt really get much attention.
Re: YZ125 B Tank
« Reply #16 on: September 01, 2009, 03:26:09 pm »
if you going to have a "A" then me thinks keep it original, if you running a "B" then its open to update a bit.
MY examples for ya FIRKO
« Last Edit: September 01, 2009, 03:32:35 pm by Freakshow »
Offline motomaniac
Re: YZ125 B Tank
« Reply #17 on: September 01, 2009, 03:29:26 pm »
has the A got the original rims? the B has new ones or???
Re: YZ125 B Tank
« Reply #18 on: September 01, 2009, 03:41:17 pm »
'A' had both muddies and flats infact i think there was 3 makes offered in the end, i have 2 "A" and they both have differant orignal rims ( go figure) forks where the same but most 75 ers dropped em out for the 250YZ front end and wheel, makes a  big differance.
Any one got a backing plate for a YZ 250A/B  while i think of it ?   or are they the same as ther MX 250B ?
Re: YZ125 B Tank
« Reply #19 on: September 01, 2009, 03:44:10 pm »
according to my web search here are some numbers - quite a few made for something so rare?
1975 125 YZ125B   453-100101                    101620 (qty produced)
Rossco
Offline motomaniac
Re: YZ125 B Tank
« Reply #20 on: September 01, 2009, 03:53:08 pm »
Rossco
but not many in OZ.
Re: YZ125 B Tank
« Reply #21 on: September 01, 2009, 03:56:23 pm »
I wouldnt say 1,519 is a lot of bikes Ross ?
I think your misreading  the info you have, thats the serial spread.
you take the starting production number from the last serial production model, you can also add about 200 left cases and frames to any yamaha model as they sold them as a replacement part , often with blank cases or no numbers
453 -100101  to  453 - 101620
« Last Edit: September 01, 2009, 03:59:52 pm by Freakshow »
Offline suzuki27
Re: YZ125 B Tank
« Reply #22 on: September 01, 2009, 04:21:38 pm »
It has the same colours etc of the YZ80B (1975).I have seen plenty of those but I can't recall seeing a 125B- until now that is. It wouldn't of had the LTR rear though would it?
Offline motomaniac
Re: YZ125 B Tank
« Reply #23 on: September 01, 2009, 04:34:42 pm »
Ithink that you are right about the LTR , might be a  mod but the MX125B (also rare) did have slightly canted shocks like that.
Re: YZ125 B Tank
« Reply #24 on: September 01, 2009, 05:51:05 pm »
OK Freaky - that makes sense as I thought 101 odd thousand was far from rare!!!! :P
Rossco
Re: YZ125 B Tank
« Reply #25 on: September 01, 2009, 09:20:31 pm »
The MX125B is a white replica of the MX125A - including the upright rear shocks.
The rare MX125C had lay-down twin shocks from the factory (very similar to a TT500).
WRT the YZ125A rims, they came with Jap Mudcatchers, Takasago mudless, or DID mudless.
Offline motomaniac
Re: YZ125 B Tank
« Reply #26 on: September 01, 2009, 09:24:33 pm »
You are right I was thinking of the C with the laydowns
