Author Topic: Pre 75 husky parts  (Read 3586 times)
Offline DG 26
  • 250H 125D it490 looking for pre75bike
Pre 75 husky parts
« on: August 31, 2009, 06:39:08 pm »
G,day
looking for parts/info to make a RT250 into a good pre75 racer
CR frame,barrel gearbox Basket case CR/WR,s ? :)
Don
albrid-3
Re: Pre 75 husky parts
« Reply #1 on: August 31, 2009, 07:52:53 pm »
Don, their is plenty of husky parts out there, call Bendigo Dirt Bikes Victoria  ask for Michael  he may have something.
« Reply #2 on: August 31, 2009, 09:11:10 pm »
Hello Don,
I have a pre'75 CR frame, MK I think, I will check & let you know. Maybe something else around as well.
Offline Husk72
  • Attitude? What effing attitude?
« Reply #3 on: September 01, 2009, 07:27:45 am »
Hey Don.
If you haven't already done so,try Husky Parts Australia,web site- huskyparts.com.au.
Its run by Fernando Franco,very helpful and on the ball.
All his contact details etc,are on the site.
                              Cheers,Mark.
I used to drink a lot.
I still do,but I used to,too.
Offline JC
« Reply #4 on: September 02, 2009, 10:35:00 am »
Don, this is a project I've considered too. I'm not a Husky guru, but FWIW here's what I planned as a suggestion, probably in this order:
1. Lose weight, lose weight, lose weight. Remove all the obvious things of course, incl excess brackets on frame. I'm lead to believe the frame is only slightly heavier than the CR (MJ/MK) frame so probably not worth replacing, but rear wheel & airbox are much heavier, so replace them w CR ones. Seatbase maybe worth replacing too. Alloy rims in place of steel ones. Lighter, smaller (alloy?) tank. Later (73/74ff) mag forks were lighter too, both sliders & tubes.
2. Power up. Start w better pipe & carb. RT was strangled w asthmatic pipe & small carb, but I suspect RT barrel maybe same as MX of the day (pre-reedvalve engine). If RT barrel is not sufficient try 74/75 reed-valve barrel. Or some porting. Maybe raise compression. All the usual stuff.
3. Suspension upgrade. YSS PD valve & decent shocks??
4. Gearbox ratios. RT ratios 1-4 are not too wide, but its a big jump to 5th (23%). If my specs are correct, replacing 5th gear w MX ratio closes the gap nicely to 16%. (5th gear MX is 0.74; 5th gear RT is 0.678; both are 0.88 for 4th as far as I can tell). Just rememeber it'll have to be from the 5sp MX box, not 6sp
5. VintageHusky type frame mod?? (for better steering - moves the seat forward & up, thereby improving the ergonomics & weight distribution)  But this maybe technically illegal for pre-75 as it does change the position of the rear top shock mount a little.
« Last Edit: September 03, 2009, 09:15:48 am by JC »
Offline DG 26
« Reply #5 on: September 03, 2009, 08:18:32 pm »
Thanks all
will chase up/check out all the info and get back to you all soon
Don
