Author Topic: 36mm mikuni 2.5 or 3.0 slide  (Read 3011 times)
« on: August 25, 2009, 06:34:03 am »
hi
anyone got a spare 2.5 or 3.0 mikuni slide for my 36mm mikuni.i have 34mm and 38mm carbys and the slides dont interchange. the 1 i am using is a 1.5,
jim
Offline pmc57
Re: 36mm mikuni 2.5 or 3.0 slide
« Reply #1 on: August 25, 2009, 08:42:05 pm »
and what happens when you use the 1.5, why do you want to go to a 2.5 or 3.0?
I'm interested because I've been playing about with carbs lately
« Reply #2 on: August 25, 2009, 09:22:20 pm »
pmc57
as slide go up in size 1 1.5 2 2.5 3
the higher the no the leaner it is
the motor is a little rich on the initial turn of the twist grip.
opened up it flys.thought the clutch was slipping in yesterdays little test.pulled it apart it fine.looked at my test track 2 trenches 1 each way.what i thought was clutch slp was wheel spin
jim
Offline oldyzman
  • 250 two stroke!
« Reply #3 on: August 25, 2009, 10:04:17 pm »
Hey Jim what bike is it for?
« Reply #4 on: August 25, 2009, 10:11:33 pm »
1972 cz400
geting it ready for dirt track nationals
Offline Tim37
  • Its an investment ...had to buy it !
« Reply #5 on: August 27, 2009, 08:29:54 am »
Just file the slide , with great care to a 2.5 mm cutaway .......if not I think I have one cheers Tim
« Reply #6 on: August 27, 2009, 08:41:07 am »
tim
how do you know what the cutaway size is i have a 1.5 do i just file 1mm off the top of the slide (the round bit).i know not to touch the bottom
jim
