Author Topic: XT 500 Kick Starter  (Read 3398 times)
Offline PB
XT 500 Kick Starter
« on: August 23, 2009, 09:38:17 pm »
Wanted - Original Kick Starter for a 76 XT500 preferred, any kick starter will do that will fit.
Bundi
Re: XT 500 Kick Starter
« Reply #1 on: August 23, 2009, 10:29:21 pm »
hi
i use a mx360a kick starter on my tt500 slider
« Reply #2 on: August 24, 2009, 01:15:02 am »
xs650/750 kickers fit on the splines and appear to have the correct offset to clear frames and footpegs but can adjusted with a heat torch if need be
Offline PB
« Reply #3 on: August 24, 2009, 08:40:58 pm »
Thanks for the heads up guys. Its good I have other options.
« Reply #4 on: August 24, 2009, 09:41:47 pm »
dt,rd,xv any model 250 plus cc seem to have the same size kicker shaft so theres lots of options for "specials" on models up to the early 80's
ChrisACT
« Reply #5 on: August 24, 2009, 11:12:26 pm »
I bought an RZ350 kick start lever and boss to run on my DT2.  The splines inside diameter are too small to run on the DT2 kick shaft.  I believe the DT2 shaft is the same as the SR/XT/TT500.  I want to retain the RZ lever as it will clear the footpegs better, but I need to find a boss (like an XT500 item) to put the RZ lever on.
My point is that not all 250cc+ kick start lever will fit.
Also, if anyone has an XT500 or similar kick starter boss they would like to sell to me, I'd be interested.
« Reply #6 on: August 25, 2009, 01:53:53 am »
i dont remember rz being in that list only rd and didnt rz come out in the early 80's?
« Reply #7 on: August 25, 2009, 06:06:51 am »
mx250 mx360 fit ihave one on my tt500
ChrisACT
« Reply #8 on: August 25, 2009, 07:52:30 am »
Yes, RZ was early eighties but had virtually the same bottom end as the RD's.
« Reply #9 on: August 25, 2009, 12:57:34 pm »
All of the AT1, CT1, DT1, RT1 type bikes have the right spline.
All of the MX and DT250/360/400s have the right spline.
All of the early YZ250/360/400s with the pinch-bolt in the lever have the right spline.
All of the early IT250/400s with the pinch-bolt in the lever have the right spline.
The early type (single cam) XT250s have the right spline.
I'm sure that there are others, but those ones I know.
I can't talk sensibly about whether they'll clear the frame, except to say that I'm pretty sure an AT1 or CT1 lever will NOT clear.
