Clubroom
Tech Talk
WP shock service
Topic: WP shock service (Read 2388 times)
RMJJ
WP shock service
August 19, 2009, 07:14:54 pm »
I've got a wp single shock circa early 80's
It was leaking so I've fitted a new quad ring seal.
I cannot suss out how the seal head seals the shock while filling it with oil.
The seal head is tapered and so is the cap. In between these two parts is an O ring which gets trapped on the taper.
The thing is the seal head slides inside the shock body so the O ring doesn't get compressed by the taper and doesn't seal.
Can anyone explain how it works/seals
brent j
Darwin, NT. Suzuki tragic, RL250M TS90MX PE250B
Re: WP shock service
August 19, 2009, 07:33:02 pm »
Mine has a steel wire type circlip that sits under the seal head, in the body.
It's very easy to lose it on disassembly.
Brent
ola_martin
August 19, 2009, 07:37:50 pm »
That's correct, it sits on a circlip.
RMJJ, I tried to answer you in adrenalintrip but can't make it work since the forum has turned "black", do I need a new approval from the webmasters? My loginname works but I'm not alowed to post....
RMJJ
August 19, 2009, 08:29:33 pm »
Ok. Thankyou.
It must have been missing when I got the shock.
Easily sorted out. Thanks
Clubroom
Tech Talk
WP shock service
