Author Topic: Seat for TS 250A 1976  (Read 1392 times)
TM BILL
« on: August 18, 2009, 05:32:40 pm »
Wanted a seat to fit a Suzuki TS 250A 1976 , they are different to the other TS 250 models thanks Bill  :)
Re: Seat for TS 250A 1976
« Reply #1 on: August 19, 2009, 07:38:14 pm »
doh.... i have a 76 model out side the back, and would you believe its the bit that not there.
wacky looking carby i can do...
Also while i think about  it Did you ever get that Chrome 125 barrell rechromed that adam shafted you on ? if so how does that work and how much ? or did you just get a new steel liner cut ?
Also can you run a normal steel liner piston with just the special chrome rings ?  were do you get the chrome rings ?
TM BILL
« Reply #2 on: August 20, 2009, 09:10:46 am »
Gidday Kerry shame about the seat  :'( and yep them carbs are different all right  ???
Did you know that that TS 250 A model also uses a Plated cylinder  ??? as far as i know the only Suzuki trail bike to do so .
That Cylinder Mrs Scard screwed me over on is still on the shelf  :o I bought it for a spare as my 125A has a Nogouchi cylinder on it  :)
It looks like DJ may be taking all the YZ 125A stuff off me (if he can tear himself away from the wildlife shows on discovery long enough to close the deal  ;D )
The Cylinder will probably get replated over here ( Approx $NZ500.00 ) and he will probably run a DT piston with steel rings as i dont think the Chrome ones are compatible  ??? (happy to be corrected though ).
« Reply #4 on: August 20, 2009, 06:33:51 pm »
YZ 125 parts ? talk to me.
At that price wouldnt you be better off putting a steel liner in there ? custom matched and fitted only $350 AU, then you wont need to chase those special rings that you can never find
