Author Topic: Husqvarna with Reverse Gear  (Read 5211 times)
Offline Snowy 76
« on: August 16, 2009, 05:09:22 pm »
WHY? Does my 76 cr250 have reverse ? checked all the brochures it wasn`t a option. ;) It`s done it maybe 6 times in 3 years of racing. Happened first pre 78 race of the Nationals and I have witnesses. I dont notice any difference in the way the engine is running and I just have pull clutch and retry 2 maybe 3 times and she`s all good. Very Strange?
Couple of CR`s
Re: Husqvarna with Reverse Gear
« Reply #1 on: August 16, 2009, 05:19:23 pm »
was the motor running backwards?a common thing on plenty of two pokers
Curly3
« Reply #2 on: August 16, 2009, 06:32:58 pm »
Did it back fire before it happened?
I had a TC80 Suzuki in the late 60's that several A grade Short Circuit guys loved to push start it in reverse and see who could ride it the fastest.
This usually happened late in the day at clubkarna's, always after a few bevvy's of course and was very funny.
TT
« Reply #3 on: August 16, 2009, 06:36:53 pm »
A mate had an RV90 that did that.
We took turns trying to ride it too.  :D :D
But without the beer............... we were only about 12 at the time.....................  :-\
Offline Noel
« Reply #4 on: August 16, 2009, 07:54:08 pm »
Snowy,
Talk to Pete,
He said it is a gearbox issue, something to do with the clutch running in the opposite direction to the engine and causing the out put shaft to run backwards,
gearbox needs to be stripped and rebuilt ;D
Noel
Rosco400
« Reply #5 on: August 18, 2009, 07:09:05 am »
You werent sitting on the bike backwards were you :-[
Offline Brian Watson
  • First Penton in OZ
« Reply #6 on: August 18, 2009, 09:53:34 am »
I had a 250 that did that once..it is an ignition timing problem...timing set too close to TDC or the flywheel key is broken..and when you start it the engine runs backwards...let the clutch out and hey presto reverse..!! Check the timing first.. :)
Offline Wombat
  • Gold Coast hinterland
« Reply #7 on: August 18, 2009, 09:54:46 am »
Did it get wet? I had a YZ125C go into reverse after I dropped it in a creek.
Pulled it out and when it re-started it ran really rough - and went backwards when clicked into gear.
Kept on trying and it would only go backwards.
I gave it to the local bike shop and all they did was ride it around for an hour trying to get it to go backwards!
So they did nothing. I can only assume it dried out - and got better! :D
"Whadaya mean it's too loud?! It's a f*ckin' race bike!! That pipe makes it go louder - and look faster!!"
Offline JC
« Reply #8 on: August 18, 2009, 10:10:58 am »
I'd have tho't ign timing too, only the other direction - too much advance causing it to backfire (on startup or at idle) & counter-rotate.
Offline Snowy 76
« Reply #9 on: August 18, 2009, 10:42:03 pm »
Got a Couple off the Husky Experts thinking about this, Checked the Timing, All good, dont have to stop engine and re-start bike to get forward motion.
Couple of CR`s
090
« Reply #10 on: August 19, 2009, 06:02:27 am »
One thing you didnt mention is that there is no backfire.
Isn't there a Husky ad that says something about this?
Goes something like " Husky's run away from the competition ! "
Yeah, running back out the start area and into the van!
Maybe the bike was once part of a circus act?  ;D
shoey
« Reply #11 on: August 19, 2009, 09:23:09 am »
Gee Champ
Your hilarious
You could have another career after MX and restoring motor bikes.
maybe something like Comedy perhaps , keep practicing you have a way to go.
Offline ba-02-xr
« Reply #12 on: August 19, 2009, 11:37:24 am »
I know this will sound really stupid but have you replaced the plug. I once hade a pump motor giving me "ingnition proplems". Everyone swore it was a sheared flywheel key. Giving a wrong ing timing. After going through every ign part despit the plug looking fine with great spark I replaced that. Fixed problem. All we came up with was it was acting as a cap & holding charge for a short time & delaying its bang.
Offline bazza
« Reply #13 on: August 19, 2009, 07:13:04 pm »
husky pete would know if gearbox have heard of huskys timing out and go backwards.
Embrace patina
090
« Reply #14 on: August 20, 2009, 05:50:23 pm »
Gee Champ
Your hilarious
Yeah too true. I said something at riders briefing that went off like a fart in an elevator. Teach me for trying the same gag twice(wanker)  ::)
